V8 Swap Questions
Old Apr 28, 2018 | 10:49 AM
Wolf Mxbee's Avatar
V8 Swap Questions
Okay to start off differently then any other person who’s asked this as I know a few can get quite annoyed with these type of questions but I’m not asking how or what is needed as I have a list of items others have needed to do the swap but I do need help in some parts:
- The body control module (under the passenger side dash) do I need a “GT” one or are they both the same?
- Is the fuse box in the engine bay the same from the V6 as the GT or will I need to pick one up?
- Are motor mounts (not the brackets to the motor, but the motor “bushings” that attach to the frame or k-member) on the V6 the same as V8 because I noticed they looked similar?
- What interchangeable parts are there between the two motors
- Is the fuel pump different? Or is it just the GT lines I need to run?
Old Apr 28, 2018 | 02:51 PM
07 Boss's Avatar
If you look up part numbers for those you can find out if they are interchangeable.
Old Apr 28, 2018 | 10:39 PM
Wolf Mxbee's Avatar
Thanks I’ll try it
Old Apr 30, 2018 | 07:31 AM
hobojack's Avatar
I have used GT sjb and fuse box in my V6. It is my understanding the pumps are the same. I don't know about the motor mounts.
Old May 5, 2018 | 12:47 PM
Wolf Mxbee's Avatar
Thanks for the help guys, it’s been tricky finding part numbers as some parts are not available to find but from what I’ve found, motor mounts are the same, fuse box is the same as well as the junction box under the dash, still researching on much more though
97GT03SVT
1994-2004 V-8
Jan 8, 2014 03:25 PM
Dubya11
05-09 Interior and Audio Mods
May 19, 2011 12:46 PM
Automagically
Jan 18, 2011 03:11 PM
mustangpowers
Sep 22, 2010 08:30 PM
1973Mach1
Dec 6, 2006 06:47 PM
