Upgraded suspension with Fanblades and 18" Bullitts?
Old Aug 21, 2006 | 02:22 AM
IWantMyNewGT's Avatar
I believe this question was asked awhile back before the server meltdown. I can't find it now with a search so I'm asking it again since I'm trying to finalize my option list before ordering an '07.
Is the factory suspension different/upgraded when you order one of the 18" wheel options vs. staying with the 17s? I checked the Ford site and can't find anything there, either. Thanks in advance.
Old Aug 21, 2006 | 11:16 AM
First Stang's Avatar
Found this on the Canadian Ford Media site:
"In the 2006 model year, Mustang GT also will have new a choice of two new 18-inch polished aluminum wheels – the largest tires ever fitted to a production V-8 Mustang since the 2000 SVT Cobra R model – and unique suspension tuning calibrated to the larger treads."
I assume this would apply to 07's?
Old Aug 21, 2006 | 01:55 PM
BuzzyStang05's Avatar
I'm still curious about this too. The only way to know for sure is if there are different part #'s for the shocks/springs/struts available for the GT's w/ 18's. Kevin Casey, you're being paged!
Otherwise, I would think it's just marketing BS, something intended at press time but maybe never put into production?
Old Aug 21, 2006 | 08:53 PM
Stoenr's Avatar
I have seen this asked many of times. But never an answer!
Maybe by suspension tuning, its a fancy way of saying alignment.
Then technically I might be your man to answer. Ill look at 06 specs in our Hunter machine see if theres an option.
When I aligned mine I had to use 05 specs on 06 with 18's, and it came out fine, so I dunno, I look tomorrow.
Old Aug 23, 2006 | 09:57 AM
froman6's Avatar
There is a unique shock, sway bar and steering rack.
Old Aug 23, 2006 | 01:06 PM
thecarguy's Avatar
"Steering rack"!!?? I hope that's not the case, as I ordered mine with 17s because I am going to upgrade the suspension and wheels on my own.
Old Aug 23, 2006 | 06:09 PM
incomingRPG's Avatar
Thanks, Where did you find this information?
Old Aug 24, 2006 | 01:32 PM
froman6's Avatar
I have a '06 w/18's and an engineer for Ford.
Old Aug 24, 2006 | 01:40 PM
Phorty's Avatar
You have an engineer for Ford? I want one.
Old Aug 25, 2006 | 12:54 PM
froman6's Avatar
There might be 6000 of us next month.....more layoff's on the way. I'll look you up! :-}
Old Aug 25, 2006 | 01:34 PM
thecarguy's Avatar
Is it a faster or slower steering rack? What are the specific specs of the two?
Old Aug 26, 2006 | 09:53 AM
froman6's Avatar
Just the internal valving is different to accept the higher loads of the 18's. Dapens steering wheel nibble better.
Old Aug 26, 2006 | 10:53 AM
thecarguy's Avatar
So if I am going to install Tokico D-Specs and Eibach pro-Kit along with a set of 19lb. 18x10s on all four corners - I shouldn't be bothered at all that I didn't order the car with 18s? In other words, the differences in the steering rack alone if it's not a quicker ratio - shouldn't bumb me out considering the above parts have waiting to be installed next weekend when my car arrives?
Wow, sorry for the wordy questions!
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
