Trunk Alignment
Hi all,
Just wondering if the trunk supports have any adjustment ? My trunk on the left side is about 1/8" lower all the way along the top, and you can really see it from the back.
Thanks for the input.
Originally posted by Fastrack@July 21, 2005, 7:37 PM
Hi all,
Just wondering if the trunk supports have any adjustment ? My trunk on the left side is about 1/8" lower all the way along the top, and you can really see from the back.
Hi all,
Originally posted by WERKED 66@July 21, 2005, 8:14 PM
try using the bumper on the lid it may be to tight on one side...
I'm assuming you don't mean the 2 little spring thingy's as that had no affect.
Hi all,
Hi all,
Originally posted by tech@July 22, 2005, 12:40 PM
The latch ring mounted to the inside center of the trunk (not the lid) is adjustable. I had the same type of problem. You will have to take off the plastic cowling on the back of the trunk (this is easy). And it may take you a few tries with a ratchet.
I never even thought of adjusting that! I had to adjust that on my Taurus too.
Originally posted by Fastrack@July 22, 2005, 12:51 PM
Thanks! Very cool, I will check it out.
Ok I just tried that, it seemed to work quite well. I raised the bracket to it's max height and tightened it up. It's a bit too high on the right side, but you don't even notice now!
Thanks all,
Thanks all,
Thanks all,
I just got really **** about this becuase it's very noticable if it's off on light colored cars.
9/16/15 06:44 PM
robjh22
9/8/15 12:31 PM
