Trunk Alignment
Old Jul 21, 2005 | 05:34 PM
Fastrack's Avatar
Hi all,
Just wondering if the trunk supports have any adjustment ? My trunk on the left side is about 1/8" lower all the way along the top, and you can really see it from the back.
Thanks for the input.
Old Jul 21, 2005 | 05:36 PM
Fastrack's Avatar
Originally posted by Fastrack@July 21, 2005, 7:37 PM
Hi all,
Just wondering if the trunk supports have any adjustment ? My trunk on the left side is about 1/8" lower all the way along the top, and you can really see from the back.
Oops posted in the wrong section, meant to post in the main forum. Pls move if you wish.
Old Jul 21, 2005 | 06:11 PM
WERKED 66's Avatar
try using the bumper on the lid it may be to tight on one side...
Old Jul 21, 2005 | 07:58 PM
Fastrack's Avatar
The bumper ? Are they adjustable ?
I'm assuming you don't mean the 2 little spring thingy's as that had no affect.
Old Jul 21, 2005 | 10:17 PM
LordBritish's Avatar
Take it to the dealer. I had the same problem and they made it better - but not perfect yet.
My trunk lid was too high on one side and too low on the other side.
Old Jul 22, 2005 | 07:24 AM
Fastrack's Avatar
bump
Old Jul 22, 2005 | 10:37 AM
tech's Avatar
Hi all,
The latch ring mounted to the inside center of the trunk (not the lid) is adjustable. I had the same type of problem. You will have to take off the plastic cowling on the back of the trunk (this is easy). And it may take you a few tries with a ratchet.
Old Jul 22, 2005 | 10:48 AM
Fastrack's Avatar
Thanks! Very cool, I will check it out.
I never even thought of adjusting that! I had to adjust that on my Taurus too.
Old Jul 22, 2005 | 02:01 PM
Fastrack's Avatar
Ok I just tried that, it seemed to work quite well. I raised the bracket to it's max height and tightened it up. It's a bit too high on the right side, but you don't even notice now!
Thanks all,
Old Jul 22, 2005 | 02:58 PM
tech's Avatar
Thanks all,
Yes, i noticed this problem as well when adjusting it. The good part is that it moves in all directions. So if it's too high on one end turn the bracket in the direction of that side going down (confusing?) and it should lower it a bit.
I just got really **** about this becuase it's very noticable if it's off on light colored cars.
Old Jul 22, 2005 | 03:03 PM
JustFord0099's Avatar
dont slam your trunk so hard thatll mess up the trunk strike and latch
OneCoolGT
Dec 10, 2015 07:55 PM
TMDM
Sep 24, 2015 07:00 PM
BigHoss
Sep 21, 2015 10:03 AM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
