tranny help plz anybody
Old Nov 22, 2011 | 02:40 AM
CancerBoi69's Avatar
OK my Stang is a 2005 v6 auto and im at about 110,000miles is it OK to change the tyranny fluid or just leave it alone and also is there any parts I can add to give my car some power don't know much about trannys. Any info would help
Old Nov 22, 2011 | 06:24 PM
HOSS429's Avatar
legacy Tms Member
if you have`nt changed fluid in 110 thousand miles dont do it now ..as far as power get a V8 .
Old Nov 23, 2011 | 12:12 AM
Hytek's Avatar
Welcome to TMS! Why do you want to change the fluid? Is it shifting bad? How does the fluid look? Is it still a red/pinkish color or nasty brown? If it's still red in color your fine. Nasty brown, I would only do a drain and fill if you're going to do anything. Don't flush it. I had a Lincoln Mark VIII years ago and did a flush and it started slipping. 3 weeks later it needed a rebuild. As for a good power adder, a cold air intake and tune will give you the best bang for your buck.
Old Nov 26, 2011 | 03:50 PM
JimC's Avatar
legacy Tms Member
Since there is no dipstick there isn't any method to check the fluid color. The automatic is a sealed unit. Won't know the color until he drains it - and then will need to refill the transmission anyway.
There is a procedure and special tool you need to refill the transmission - not something you can get done at the local quick oil change place.
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Rog13GTCS
Jul 19, 2015 02:46 PM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
Kgilly
Jul 9, 2015 01:47 PM
