TPMS Tire Pressure Monitoring System
Old Aug 2, 2006 | 01:32 PM
  #61
05retro's Avatar
Hopefully its not as sensitive as the computer. otherwise a half a pound would cause the alarm to sound. Could they make the system driver adjustable? Set limits for when the alarm goes off?
Old Aug 27, 2006 | 08:59 AM
  #62
05stangkc's Avatar
bump!!!!!!!!!!!!!!
Old Aug 27, 2006 | 09:02 AM
  #63
FStrike's Avatar
Thanks for the bump!! must have missed this thread.
Old Aug 27, 2006 | 09:03 AM
  #64
05stangkc's Avatar
it An Oldie! Nov 05!!!!!!!!!!!!!!
Old Aug 27, 2006 | 09:05 AM
  #65
05stangkc's Avatar
BTW FORD STILL DOES NOT HAVE THE 20" Straps! But there are Some Aftermarket Companies Making Them!
kc
Old Aug 27, 2006 | 09:12 PM
  #66
blownGT's Avatar
Just to add some info about operating without the sensors. I just got an 07 GT and swapped out the stock 17" wheels for some aftermarket 18" wheels without sensors before I found out about the TPMS issue. After about 50 miles I got a fault message, but, the good news is all I have to do is press reset to clear the message. The warning light below the tack also goes out after a few seconds. You have to do this evey time you start up, but at least I can drive it until I can get the sensors for the 18" wheels.
Old Aug 27, 2006 | 09:29 PM
  #67
Cheese302's Avatar
ugh one more thing to worry about, maybe i will just stick to 17"'s
Old Aug 27, 2006 | 09:42 PM
  #68
neil07gt's Avatar
some days i get a sensor fault and other days its fine. i would rather not have a tire sensor at all. I know i should take the car in have the dealer fix it, but i hate to be without my car. On days when it acts up, i press the reset button to shut it up.
The tire pressure sensor and the heated seats i could do without.
Old Aug 28, 2006 | 07:14 AM
  #69
Cheese302's Avatar
why the heated seats too? One of the reasons i waited to order a 2007 was to have the seats.
Old Aug 29, 2006 | 11:33 AM
  #70
FStrike's Avatar
I know the TPMS system is mandated in the US for 2007+ but does anyone know if vehicles ordered in Canada also come standard with the option?
Old Sep 5, 2006 | 09:26 PM
  #71
blownGT's Avatar
After living without the sensors for seveal hundred miles now, for me ayway they're pretty much a non issue. I do get a fault message from time to time but it's easily cleared with the reset button. Since new sensors for my 18" wheels are in the area of $165 plus another $75 or so to have them installed (dismount tires, install, remount and balance) I think I can live with pressing the reset button every once in a while.
Old Sep 5, 2006 | 11:49 PM
  #72
neil07gt's Avatar
Does anyone know what causes a Tire Pressure Sensor Fault? It comes and it goes. I'll have a Fault, and then it will go away overnight and be gone for a week or more, only to show up again. Dang I just hate taking something for repair and saying "yeah it's working now, but trust me 2 days ago it wasn't".
Old Sep 7, 2006 | 06:51 PM
  #73
Bob99b5's Avatar
Ok, please don't call me a dummy but where is the TPMS reset switch? Mine came on the other day (one tire was down 5 lbs) but it went off immediately after I added air. I never pressed a reset switch and I never knew there was one.
Old Sep 7, 2006 | 09:22 PM
  #74
blownGT's Avatar
It's the reset button on next to the info and setup buttons on the upper center console
Attachment 8803
Old Sep 21, 2006 | 12:30 PM
  #75
FordEvangelist's Avatar
Does anyone know if the sensors measure tire speed (relative to the other tires) or do they actually measure the air pressure in the tire?
Old Sep 21, 2006 | 01:17 PM
  #76
theedge67's Avatar
Not sure why they would measure tire speed...they would have to be pretty sensitive to measure any differences in speed for low vs. normal tires. That would be almost undetectable. There is pressure sensors inside the rims, they measure each tire pressure compared to the other 3 tires. Theoretically, if all 4 tires went flat at the same time and at the same rate, the system would not detect it. Chances of that are slim to none though.
Old Sep 21, 2006 | 01:18 PM
  #77
ipchay61's Avatar
I'm pretty certain they measure pressure. Mine came on sitting still in the garage when the tire pressure was down 7 lbs.
-Chip in SC
Old Sep 21, 2006 | 01:20 PM
  #78
ipchay61's Avatar
I read somewhere that the warning would alarm if the pressure got down to 25% below the Manufacturer's Recommended level ( listed on the door jam).
Chip in SC
Old Sep 21, 2006 | 01:57 PM
  #79
AWmustang's Avatar
Early systems used wheel speed to determine low tire pressure. Manufacturers tried this because the car already has all the equipment it needs (4 channel ABS). However the tire has to lose a lot of pressure before the system is triggered. Also, it would not notice if all tires slowly leaked.
The government mandated these to protect idiots from themselves. People who drive on severally low pressure for extended periods of time. Therefore these new systems measure the actual pressure of each tire and do not compare it to the other tires.
http://www.nhtsa.dot.gov/cars/rules/...FEA/TPMS2.html
Old Sep 22, 2006 | 06:51 AM
  #80
theedge67's Avatar
I guess these are the "next generation" pressure sensors then, cool!
