Tire size...
Old Oct 27, 2008 | 03:39 PM
Starfire's Avatar
Tire size...
Do you think I could get away with a 235/55/18 opposed to the stock 235/50/18? Looking to get some snow tires and there are a lot more in 235/55/18.
Thanks!
Old Oct 27, 2008 | 09:57 PM
Showmee's Avatar
Hi i did a little checking and a 235/55r18= 28.3" diameter and a 235/50r18= 27.4" diameter. That is the specs for Bridgestone Blizzak tires at tire rack. Hope this helps.
Old Oct 28, 2008 | 03:51 PM
Starfire's Avatar
I know, I mean do you think there will be any problem with running them at 55?
Old Oct 28, 2008 | 03:55 PM
Ministang's Avatar
Shouldn't be a problem. Your speedometer and odometer will be off by around 3% because of the size difference, but you should be able to change your tuner to compensate for that.
Old Oct 29, 2008 | 04:29 PM
Stoenr's Avatar
What he said. And "if" you have a tuner. But if not, its still not a huge deal.
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
