Starting in 2nd Gear
Old Aug 1, 2005 | 03:03 PM
icemant180's Avatar
Will taking off in second gear at 4 or 5k rpms cause damage to the Tremec or Transmission? If not, do people do this at the track for a quicker launch.
I seen a show awhile back where they took several different muscle cars from the 60's and ran them through a few different tests. One of the tests was the burnout and he was gunning it in second gear from the get go.
Old Aug 1, 2005 | 03:21 PM
The Boss Hog's Avatar
Originally posted by icemant180+August 1, 2005, 5:06 PM--><div class='quotetop'>QUOTE(icemant180 @ August 1, 2005, 5:06 PM)</div><div class='quotemain'>Will taking off in second gear at 4 or 5k rpms cause damage to the Tremec or Transmission? [/b]
the Tremec is the transmission and it won't do it much good but the biggest loser will be your clutch.
It will result in either 1.) too much wheel spin or 2.) bog. Either will result in a slower launch.
<!--QuoteBegin-icemant180
[/quote]
For the purpose of "burning out", yes the 2nd gear launch will do the trick. 60's muscle cars typically had larger CID engines with much more low end torque than the 4.6 3v has. Second gear "smoke shows" where no problem.
Hope that answers your questions.
The Boss Hog
Old Aug 1, 2005 | 03:38 PM
1 COBRA's Avatar
My crystal ball says you'll become very familiar with the clunk in the near future.
Old Aug 1, 2005 | 04:21 PM
icemant180's Avatar
Thanks Boss. You are a wealth of information. :worship:
Old Aug 1, 2005 | 04:44 PM
holeshot's Avatar
if you dump the clutch from a dead stop while in 2nd gear it wont do much of anything except smoke your clutch. trust me....no 2nd gear burnouts in the 05, i've tried.
Old Aug 1, 2005 | 04:59 PM
eighty6gt's Avatar
Install 4.30's first.
38special's Avatar
I have tried a 2nd gear launch at the track, and did not like the result. Seemed slower to get up to speed, but spun tires less. Did not do it again.
Old Aug 4, 2005 | 11:51 AM
Big Poppa's Avatar
I tried a 2nd gear burnout and the only thing that burnt was my clutch. Even with TCL turned off, it will come back on all by itself and the power that was supposed to be sent to the rear wheels get sent back to the next weakest link; your clutch disk.
Old Aug 4, 2005 | 01:15 PM
Fordracing200's Avatar
you could do it in water
Mpaps
Oct 11, 2017 08:06 PM
samjluck
Sep 17, 2015 10:24 PM
jim010
Sep 7, 2015 02:40 PM
