squeak in my drivers seat
Old Apr 3, 2008 | 03:36 PM
slipnotovk's Avatar
i recently got around to making my mustang practically 100% rattle free thanks to TMS but now i have a rattle that just cannot be reached. it sounds as if there is a squeaky spring in my drivers seat right in the middle of my back. if i rock back and forth you can hear it plain as day. anyone know if possibly the factory warantee would cover such a thing? i thought id ask on here to see if anyone else has had the same problem.
Old Apr 3, 2008 | 07:07 PM
Gleamin05's Avatar
I have the same problem with my drivers seat as well if you press back in a certain spot..about middle of the back seems to happen with warmer temps with mine. Yes Warranty will cover it ,unfortunatly I'm out of warranty so I guess I'll be taking the seat apart myseft to fix it eventually.
Old Apr 3, 2008 | 11:27 PM
classj's Avatar
Mine does this as well and I think I am onto the problem. I have to confirm though. If you move the drivers seat forward all the way there is a plastic cover on the rear of the seat tracks on the floor. My outboard cover squeaks pretty bad when moved a bit. (noticed when vacuuming the rugs).
So, I am going to hit it with a little silicone grease or spray on the squeaky spots and see what happens.
Old Apr 4, 2008 | 04:37 AM
ravenblack67's Avatar
I have been looking for a solution to this noise since dec 2004. Silicone, grease, WD-40 have not helped. Mine only makes the noise at idle in drive. I'm going to remove the seat and try adding small pads in various locations.
Old Apr 4, 2008 | 01:17 PM
slipnotovk's Avatar
i know it is inside the seat only because if i sit in it and reach around back and press i can make it stop. it is def going to require removing the leather to fix the problem but just as long as it is under warantee i could care less.
Old Apr 7, 2008 | 10:19 AM
krnpimpsta's Avatar
I had a squeak that I couldn't place, but it turned out to by my seatbelt recepticle rubbing against my seat as it rotated.
Old Apr 7, 2008 | 02:00 PM
jmk3's Avatar
My seat belt receptacle squeaks against the side of my seat also, a small piece of felt fixed it right up. Sounded more serious until I realized it was just squeaking against the pleather.
Old Apr 7, 2008 | 02:35 PM
gmantheman's Avatar
My drivers seat is fine, but the passenger seat rattles.
kponypower
Jun 17, 2020 07:17 AM
Autotooner
Nov 24, 2017 12:42 PM
yabutt
Oct 23, 2015 01:05 PM
Evil_Capri
Sep 25, 2015 12:56 PM
