Spec 2+ Clutch Owners: Step Inside
Old Aug 23, 2010 | 03:31 PM
Gene K's Avatar
This is posted in the 2005-2009 section because this is where the experience is.
On a bolt-on to mildly supercharged car (Under 400 rwt) how have those that used the Spec 2+ clutch felt about its engagement characteristics? Slippable or all or nothing? Does it disengage fully for shifting? Any slippage? How long did it last?
I have an opportunity to be a test car for Spec (on the 2011) and thats the clutch they would like to do.
Old Aug 23, 2010 | 04:05 PM
Bullitt995's Avatar
Ehhh I wouldn't be comfortable with being a test car for a clutch. Let someone else have that headache.
Old Aug 23, 2010 | 05:28 PM
Gene K's Avatar
Ive already had 4 months of headaches with Ford. Its time to do something.
Old Aug 23, 2010 | 05:31 PM
tom281's Avatar
If the new version is anything like the 05-09 version, tell them you're interested only in the 3 seriers or higher. I remember many failures in the 05-09 version of anything less than the 3 series; a friend of mine had a 2+ in his turbo GT and it lasted about 2 months after proper break-in and normal driving. I had a 3+ in my blown 06 and it was great. Just my 2 cents.
Old Aug 23, 2010 | 05:32 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
If the clutch should damage anything else in the test process is Spec going to cover the cost of replacement/repair?
Old Aug 23, 2010 | 05:53 PM
Gene K's Avatar
Its more a case of a car for fit and design and I get (hopefully) a clutch that will not stick to the floor at anything over 6500-6800 rpm like the stock clutch (pedal mods already done).
Old Aug 23, 2010 | 05:58 PM
Gene K's Avatar
They are saying the only difference between the Spec 2+ Light Pedal and the Spec 3+ for the 2005+ now is the friction material on the disc.
I think I will tell them its either Spec III+ or I wait for the 2012 Boss 302 Clutch which hopefully finally fix the issue.
Old Aug 23, 2010 | 06:04 PM
tom281's Avatar
Best of luck to you which ever way you go!
Old Aug 23, 2010 | 06:13 PM
metroplex's Avatar
FWIW, the GT500 has a TR-6060 with a multi-disc clutch (IIRC). That's the clutch setup I'd use, whether it was NA or supercharged. It seems silly to save a few hundred by going with a single disc when a twin-disc can handle much more torque. If it will cost $500 in labor to replace clutches, go for the beefier setup. Just my 2 cents. But based on my research here, the Spec 3+ is what everyone seems to recommend for a single disc clutch. I'd probably go with a multi-disc, like Exedy's Stage 4.
Old Aug 23, 2010 | 10:48 PM
Gene K's Avatar
Thanks Guys, I think Ive cooled off enough to wait on Ford to come up with a fix.
Metroplex who said I was paying for labor?
Gill5oh
Oct 6, 2017 10:50 PM
GLOCKer
Sep 28, 2015 05:20 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
