Spark plug torque spec
Old Jul 3, 2018 | 06:29 PM
VGMStudios's Avatar
Tms Mustang Member ------ The Customizer!
I've been all over the net searching for an answer.
No one seems to give a straight answer.
I want to install NGK Gpower platinum spark plugs.
What is the torque spec to tighten them?
Is it 13lbs, 25lbs, something different?
This will be my first time doing this.
Thanks.
Old Jul 3, 2018 | 09:22 PM
m05fastbackGT's Avatar
Did you search this forum? that's exactly how I found out the torque specs are 25 ft lbs torque.
Edit: Disregard the 25ft lbs torque, as those are specs for the 2005-early 08 4.6 3valve GT. I have no idea what the specs are for V6 cars.
Old Jul 3, 2018 | 10:00 PM
VGMStudios's Avatar
Yes i did search here.. Exactly, I found it for the gt but that doesn't help me. :/
Thanks for the reply.
Old Jul 3, 2018 | 10:29 PM
houtex's Avatar
According to the 2005 shop manual here, for the 4.0L:
http://iihs.net/fsm/?d=209&f=SPECIFICATIONS.pdf
It's 13 lb-ft of torque. Not all that much. Spark plugs generally aren't very torqued down.
Old Jul 4, 2018 | 06:51 AM
VGMStudios's Avatar
My goodness, thanks so much Houtex!!! I never thought of checking there!
Old Jul 4, 2018 | 11:47 AM
houtex's Avatar
One is glad to be of service!
Old Jul 4, 2018 | 12:03 PM
VGMStudios's Avatar
I also found this if anyone needs it
http://www.mustang-s.com/years/2007/...ngine_4-0l.htm
Old Jul 5, 2018 | 11:52 AM
Bert's Avatar
I guess it's a good idea to use a torque wrench and a number; but without this reminder I'd probably just go with "tight, but not too tight" . . . in other words, do it by hand until it feels about right for aluminum threads
rmaginnis
2012-2013 BOSS 302
Aug 13, 2012 07:48 PM
Tapakegovagnaps
May 9, 2012 10:33 AM
BRENSPEED
Aug 25, 2011 12:51 PM
metroplex
Dec 8, 2007 06:00 AM
