2012-2013 BOSS 302
Panard rod torque spec needed
Old May 20, 2012 | 06:24 PM
rmaginnis's Avatar
Had to lower the RH side of the Panard rod to get the axel cover off (replacing gear lube). What is the bolt torque spec. Anyone have a shop manual?
Thanks,
Rick
Old May 20, 2012 | 07:43 PM
2012YellowBoss's Avatar
Hope this helps
Old May 20, 2012 | 09:17 PM
rmaginnis's Avatar
Originally Posted by 2012YellowBoss
Hope this helps
Indeed it does. Much obliged!
Wow, is that a typo? 350 lb-ft for the UCA bolt!! Don't think I have a torque wrench that goes that high. Or the physical strength.
Old May 21, 2012 | 08:00 PM
cloud9's Avatar
I hope the tech that just installed mine got that much torque on it! He did say he took it apart and put loctite on it after he initially installed it.
Old May 21, 2012 | 08:40 PM
Holy crap! That's like more torque than most cars!
Old Aug 11, 2012 | 05:49 PM
Brandon302's Avatar
Is the lateral stiffener bar the bar above the panhard bar that attaches to the frame by two bolts and to the panhard brace by 1 long bolt?
Old Aug 13, 2012 | 04:15 AM
TMSBOSS's Avatar
http://bossmustangsonline.com/boss-h...ring-diagrams/
Old Aug 13, 2012 | 03:06 PM
Brandon302's Avatar
Awesome thanks, I need to remember to save that link as it has a ton of info.
Old Aug 13, 2012 | 07:48 PM
GT_350's Avatar
Thanks,
Rick
Here's the torque sheet from the FR500S most eveything is the same.
File Type: pdf
Ecostang
Nov 3, 2022 08:50 PM
Mackitude
Aug 17, 2015 04:14 PM
Jul 20, 2015 06:26 AM
Rog13GTCS
Jul 19, 2015 02:46 PM
