slp problem
Old Jun 25, 2007 | 12:56 PM
eddieval5's Avatar
slp problem
the clamps that came with the slps will not tighten the axle pipe and the slp exhaust pipe all the way..they are loose even though ive thighten the clamp as far as theyll go..
Old Jun 25, 2007 | 01:20 PM
RobK's Avatar
Do you have the pipes installed far enough on the over-axle pipe?
Old Jun 26, 2007 | 06:21 AM
are they loose at both ends or does one side seem tight?? Take the clamp off and measure both pipes to make sure they are the same size. If not go to autozone and get the free loaner pipe expander and make both pipes the same size.
Old Jun 26, 2007 | 06:34 AM
blkstang06's Avatar
I had SLP'S before I went with GTA's If you haven't got rid of the alignment pins grind or file them off! this helped me in getting them to fit and seal!
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
