RUST
Old Sep 6, 2016 | 01:27 AM
dancorneliu79@yahoo.com's Avatar
RUST
HELLO, yesterday i replaced my shaker 1000 headunit and i found some rust on the back of the unit and also inside, where the unit is located . i ll share some pics with you .. Is that something that i should be worried about ? whats the reason for that? is normal?
my car is 2008 mustang gt, 27k miles, one oner before me.
thank you.
Attached Thumbnails RUST-img_0079.jpg   RUST-img_0080.jpg   RUST-img_0081.jpg   RUST-img_0082.jpg   RUST-img_0083.jpg
Old Sep 6, 2016 | 11:11 AM
07 Boss's Avatar
Where is that? Under the dash?
Old Sep 6, 2016 | 11:49 AM
vistablue mustang's Avatar
Thats the dash where the head unit goes in I would guess. I don't think its a concern, at least not from what I have seen before. I had some parts in both my 2006 and 2007 inside the dash that looked like that. Some times like the rear axle, rust will build up on the surface but not eat through the metal. I remember a VERY old thread discussing this about the rear axles when the S197 first came out.
Old Sep 6, 2016 | 02:25 PM
07 Boss's Avatar
Yeah that doesn't look too bad but I might be a little concerned. Either you live in a very humid environment or you have water leaking in.
Surface rust can help as a barrier to preventing more rust under the right circumstances but in most cases doesn't. A fine smooth layer of rust is OK in a dry environment but when you get into the rougher flaky kind of rust it is a bad thing and offers no protection from further corrosion.
Old Sep 6, 2016 | 09:13 PM
tbear853's Avatar
From: the beautiful "Shenandoah Valley of Virginia"
Humidity and bare metal with no protection .... it's "normal" enough.
Old Nov 8, 2016 | 01:15 AM
and to clean the surface and use some antirust paint will work enough ?
rear axle looks the same. actually it doesnt look like a lot of. looks like a thin layer.
thank you!!
Old Nov 8, 2016 | 01:22 AM
yes, under dash and also rear axle.
Old Nov 9, 2016 | 05:22 PM
houtex's Avatar
thank you!!
You'll want this:
http://www.por15.com/
But the issue might be getting it on both sides of that panel.
I'm sort of the opinion that it isn't anything to worry 'bout, but I'd check it later on just to be sure.
jlugo
Mar 31, 2016 10:10 PM
texasvinny
Mar 27, 2016 08:28 PM
Noah Woodcock
Mar 20, 2016 12:01 PM
TMSBrad
Jun 9, 2004 01:10 PM
