Rocker moldings loose? Normal?
Old Jan 11, 2007 | 12:47 PM
metroplex's Avatar
Can you check to see if your rocker moldings are slightly loose near the two plastic rivet fasteners by the front road wheels? I removed the 2 fasteners on one side to see what I can do about installing front splash guards and then re-used those fasteners. Now it seems like I can wiggle the rocker molding ever so slightly, and the two fasteners seem to freely rotate. Do I need new fasteners?
The only 1/4" fasteners I could find at AutoZone look very different from the OEM fastners. These aftermarket fasteners have to be turned in with a screw.
Old Jan 11, 2007 | 02:06 PM
htwag's Avatar
Should not reuse the fasteners - get new ones.
Old Jan 11, 2007 | 08:31 PM
Northwest GT's Avatar
That's the answer. Those fasteners are not re-useable. Your friendly Ford dealer's parts folks will sell you a bag of new ones.
Old Jan 11, 2007 | 09:33 PM
Poco's Avatar
If you hadn't put the splash guards on just yet, check buy pushing the clip very hard and listen to see if snaps into place.I hope this helps.I had removed several rocker panels that used the same clips.
Old Jan 11, 2007 | 11:04 PM
Vermillion06's Avatar
The two pins in the wheel well are reusable: they are the same pins used on the radiator cover.
I don't think the multiple fasteners on the bottom of the cover that fasten the skirt to the body down the length of the car are reusable though.
It's normal for the side skirts to be slightly loose; not floppy, going-to-fall-off-loose, but if you pull on them they move a little bit.
Old Jan 12, 2007 | 01:29 AM
Giddyup's Avatar
Yep, they do have a little movement to them, and the 2 plastic buttons on the leading edge can spin a bit.....mine have from day 1, but we own a Mustang & there will always be all replacement parts, so no worry.
kponypower
Jun 17, 2020 07:17 AM
ricky1728
Feb 11, 2016 07:25 PM
southern stang
Sep 26, 2015 04:19 PM
jim010
Sep 14, 2015 10:15 PM
