Replacing shaker 500 head unit?
I was thinking about a head unit along these lines: http://www.crutchfield.com/p_113DPX3...U.html?tp=5684
Would that work? The only reason I am concerned is that the built in amplifier is 50x4 but the shaker system has 6 speakers?
The harness that Crutchfield would offer for that kit (add-on option) will probably be the Metra 70-5521, which has RCA connections for the right and left subwoofer channels -- you plug in those to the "Sub Out" connections on the back of the new radio, and they'll send the signal to the stock amps. Looks like on the Kenwood unit you picked, you have a two RCA connections for front speakers, and the other two can either be for the rear speakers, or the subwoofers (you'd probably pick which one in the radio's settings). Only having 4 pre-outs (RCAs) might limit you later down the road if you want to get an external amp for the door & shelf speakers, but if you're only ever planning on driving them directly w/ the Kenwood's internal amp then you're fine.
One more note on those stock subwoofer amps -- they expect a +5V turn on signal from the head unit to turn on, but most aftermarket radios use a +12V signal. This causes a "pop" from the subs when you first turn on the radio. Most people used to use a $3 voltage regulator from Radio Shack, but looks like crutchfield includes one w/ the installation gear you can buy (Axxess AFDI-5V). With the discount they give you on installation gear ($20 for the whole shebang) you might as well use that one instead of going to radioshack.
If you have anymore questions, feel free. Also there's a bunch of older threads here w/ similar installs you can check out, such as this one, or this (shameless self-promotion
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
7805 is the voltage regulator that you buy from them. $2.89, but if Crutchfield has the system with the v/r in it, buy it that way. It will be much cleaner and you don't have to worry about mis-attaching the 3 wires. It is easy to put the center on ends wrong with this.
The v/r is definitely needed if you use any aftermarket head with the Shaker wiring setup. That popping can be deafening if you have your radio up when you turned the car off. It also can, over time, blow out a weak capacitor. It's better to install the 5v regulator and play it safe from the start.
Radio Shack still has quite a few stores, and are online. Most now, are the independent franchises, but they still exist. Lack of knowledgeable employees was their downfall the past few years, along with poor instore choices. Online was the only way to shop from them most of the time. I still use them.
MRGTX
3/19/16 05:27 PM
