Rear axle replacement
Old Mar 27, 2012 | 03:21 PM
SMMFUN's Avatar
Ok, just joined the forum and need advice from the gurus. Have a V6 2005 and was hit on pass rear wheel. Bent the axle housing. Sooooo, should I try to salvage the original rear end (3:31 / 7.5) or swap it out with a used (3:31 / 8.8) from a low mileage GT? I'm leaning towards the 8.8 solution.
Old Mar 29, 2012 | 08:12 PM
JimC's Avatar
legacy Tms Member
Swap it for the 8.8 - you get a stronger rear end, plus tlok. It will probably cost you less than repairing the 7.5.
Old Mar 29, 2012 | 10:45 PM
SMMFUN's Avatar
Thanks Jim. Do you know if the driveshaft yoke/flange is the same?
Old Mar 30, 2012 | 04:42 AM
JimC's Avatar
legacy Tms Member
Use your current driveshaft, and as far as the pinion flange it depends upon the year of the 8.8 rear end. If it is from a 2005-10 then you need to swap the pinion flange to the cobra flange (lots of places have it on line). If you are lucky enough to get a rear end from a 2011+ though it is a direct swap to your 2005 driveshaft.
Old Mar 30, 2012 | 06:34 AM
5.4 DOHC's Avatar
I swapped my 7.5 (one wheel peel) to the 8.8 (posi). Easy if you get the gt driveshaft. Changing the flange requires experience. May damage the pinion crush washer.
Ecostang
Nov 3, 2022 08:50 PM
MartinM
Sep 19, 2015 02:11 PM
houtex
Aug 13, 2015 05:04 PM
glo106
Aug 11, 2015 08:29 AM
Rot Manik
1994-2004 V-8
Aug 6, 2015 05:26 PM
