Rear axle replacement
Ok, just joined the forum and need advice from the gurus. Have a V6 2005 and was hit on pass rear wheel. Bent the axle housing. Sooooo, should I try to salvage the original rear end (3:31 / 7.5) or swap it out with a used (3:31 / 8.8) from a low mileage GT? I'm leaning towards the 8.8 solution.
Use your current driveshaft, and as far as the pinion flange it depends upon the year of the 8.8 rear end. If it is from a 2005-10 then you need to swap the pinion flange to the cobra flange (lots of places have it on line). If you are lucky enough to get a rear end from a 2011+ though it is a direct swap to your 2005 driveshaft.
glo106
Aug 11, 2015 08:29 AM
