rattle- both sides
Old Jan 2, 2008 | 09:46 AM
fakenhguy's Avatar
rattle- both sides
I have a rattle in what seems to be both the driver door and passenger door when goining over bumpy surfaces. I know the car isn't perfect when it comes to rattles but it seems to be in the exact same place on both sides. Any opinions/suggestions?
Old Jan 2, 2008 | 09:56 AM
SD CALSPCL's Avatar
Same problem...easy fix. It is the small plastic panel behind the inside door handle, on both sides of the car. Tap it with your finger and you will feel it move. Pop them off, and put a small piece of double sided foam tape on it, and pop it back in.
Cheers.
Old Jan 2, 2008 | 10:14 AM
Mark S.'s Avatar
Or you can use a small piece of invisible tape and put it somewhere on the outside of the small panel and the area where it is framed (where it isn't obvious)...will make it a lot easier to remove that small panel in the event you ever have to have your door pulled apart for some future repair.
Old Jan 2, 2008 | 11:04 AM
fakenhguy's Avatar
Thumbs up
really appreciate the advice!
Mar 30, 2021 09:29 AM
kponypower
Jun 17, 2020 07:17 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
NC14GT
Sep 27, 2015 05:35 PM
