oil question
Old Apr 26, 2020 | 03:01 PM
domer94's Avatar
oil question
so im at 115k , I use mobil1 high mileage in my suburban, but im worried about using in this thing due to the seal conditioning ingredients. would anybody recommend using a high ZDDP oil like brad penn or some other racing oils? again , im just worried about what additives might do what to this motor at this mileage. for my first change I ordered up some amsoil and a ford racing filter. I don't plan on thrashing the car , but as everybody does , will have the occasional fun with it
Old Apr 27, 2020 | 08:04 AM
JimB.'s Avatar
I use the Mobil ! high millage in my explorer and have had no issues with it. Amsoil is great also although more expensive.
Old Apr 27, 2020 | 08:48 AM
Bert's Avatar
I always wondered if there was actually anything different about the "high mileage" oils; other than the label?
anyway, I'm thinking a good full synthetic like Mobil 1 EP is probably fine regardless of mileage; and I doubt any high mileage additives would do any harm (but not sure about that)
Old Apr 27, 2020 | 08:53 AM
domer94's Avatar
I did a quick read , and basically the HM oils have boosted levels of seal conditioners which I heard make the seals and gaskets swell a bit to prevent leaks. I don't know the chemistry behind it , but I didn't want to cause any leaks by affecting any internal seals. the 4.6 might be different from the small block chevy in the suburban. as far as higher zinc ZDDP oil , that's what I wonder will be better for these higher mileage.
sampey43
2007-2009 Shelby GT500
Sep 28, 2012 03:13 PM
Jps78
Jan 29, 2012 10:43 AM
elcaminoguy
Apr 5, 2008 04:36 PM
Chris728
From The Ford Salesman
Nov 12, 2007 07:40 PM
area5179
Jun 2, 2006 08:01 PM
