Oil Filter ????????
Old Sep 23, 2009 | 03:04 PM
  #41
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Originally Posted by 1chocophile
IMO, 3000 mile oil change intervals is too frequent. The manual recommends 7500 interval. I've decided to change my oil every 5000 miles, and use Mobil1 synthetic oil and Mobil1 filters. The Magnuson-Moss Warranty Act protects us against requirements to use only Ford-approved Motorcraft oil and filters. As long as the oil and filters meet industry quality standards, use of third party products won't void a warranty.
edit: my opinion about oil change interval is based on my own driving style. I can understand why some drivers would change their oil more frequently based on how they drive their cars.
I won't lie, I not only use Motorcraft because its the Ford brand, but I also use it because its cheap! Between the oil/filter with a shop discount() my oil changes run me about $25. When I first got the car I would take it to the dealer and pay the $40 to have it done which is still cheaper than most places around here. But now since I just do it myself(I love lifts, they make life wonderful) its less than a full tank of 91.
Old Sep 24, 2009 | 07:34 PM
  #42
Dixie_Flatline's Avatar
I hope you guys running long oil intervals that drive hard are using a catch can or valve cover breathers.
Also if you drive hard, 1/4 mile it, or feel you could rationalize an upgraded windage tray, you want a filter that flows freely, not one that filters a lot. In that regard a new filter will work better for you than a "broken in" one.... The danger of bad filters is when they stop flowing.... Cause even dirty oil in that instance will be better than no oil....
That report from Bob The Oil Filter Guy is great. Heard too many stories of people's engines grenading from a filter that loses it's guts and stops filtering. Now I always buy Motorcraft because the company that's on the label also happens to make the motor the filter is installed in.
Old Sep 25, 2009 | 03:40 AM
  #43
goldenpony's Avatar
The filter will not quit flowing because it gets dirty, that's what the bypass valve is for. As you say, dirty oil is better than no oil.
Old Sep 25, 2009 | 04:56 AM
  #44
topbliss's Avatar
motorcraft for me too
Old Sep 25, 2009 | 06:38 AM
  #45
define long intervals please.
Old Sep 25, 2009 | 07:24 AM
  #46
True, but only if the bypass valve works. Read that report from Bob The Oil Filter Guy. Apparently there's quite a few designs out there made from cheap materials that it's suspect if the valve would operate if the filter itself was dirty enough to be clogged.
Old Sep 25, 2009 | 04:32 PM
  #47
theedge67's Avatar
That's a good reason to only use the Motorcraft filter. You know it is high quality and made with the best materials.
dblhelx
Oct 6, 2015 08:08 PM
MustangConvert11
Sep 30, 2015 08:01 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
TripleBlack14
Sep 17, 2015 07:48 AM
