Oil Filter ????????
Old Sep 17, 2009 | 11:55 PM
jasongt06's Avatar
Oil Filter ????????
Im curious as to which oil filters everyone is using on their 05-09 4.6 3 valve engines?
Old Sep 18, 2009 | 03:31 AM
theedge67's Avatar
Use the Motorcraft one. Outstanding quality and a great price. Part number FL-820S
Old Sep 18, 2009 | 04:48 AM
jglnaz's Avatar
I have always used the Motorcraft Filters too.
Old Sep 18, 2009 | 05:24 AM
MaverickMLFD371's Avatar
Mobil 1 Oil Filter
Old Sep 18, 2009 | 05:51 AM
1fastbob's Avatar
Motorcraft!
Old Sep 18, 2009 | 05:58 AM
DEPUTY62's Avatar
from wht im hearing from forrd if u use an after market filter you can and will eventually have severe engine damage. and they wont cover the damages. my stang is in the shop no and thats the only explenation i can get from them. i used an stp oil filter once one 1 time and now im looking at a 6thousand dollar engine replacement... use the motorcraft filter!!!!!!!!!!!!!!
Old Sep 18, 2009 | 07:02 AM
BudgetPlan1's Avatar
http://www.mustangsunlimited.com/ite...0+01&dep_key1=
Old Sep 18, 2009 | 07:17 AM
crescent_wrench's Avatar
Assuming you don't put a pure crap filter on, that's reaching a bit.
Old Sep 18, 2009 | 07:26 AM
69Mach1-409's Avatar
+1 with 5W20 Mobile 1 Full Syn. My oil reports always come back outstanding.
Old Sep 18, 2009 | 07:53 AM
shadyninja's Avatar
Amsoil EAO11
along with Amsoil 0W-20
I cut a couple open
you decide which one you like better
Valvoline
inside
Amsoil
inside
take your pick
Old Sep 18, 2009 | 07:54 AM
Shotokan1509's Avatar
Amsoil EAO11 along with their 0W-30 synthetic.
http://www.amsoil.com/catalog.aspx?code=EAO11-EA
Old Sep 18, 2009 | 07:56 AM
shadyninja's Avatar
Originally Posted by Shotokan1509
beat you to it,
Old Sep 18, 2009 | 08:16 AM
Originally Posted by shadyninja
beat you to it,
Old Sep 18, 2009 | 08:40 AM
The Reverend's Avatar
Motorcraft
Old Sep 18, 2009 | 09:04 AM
825LTRGT's Avatar
Motorcraft FL-820S
Change Mobil1 5W-20 every 5k and change filter every 2500 mi
Old Sep 18, 2009 | 09:46 AM
Vermillion06's Avatar
Motorcraft is good, so are Wix & Purolator. Just stay away from Fram filters!
Old Sep 18, 2009 | 12:13 PM
jasongt06's Avatar
I usually use either a Mobil 1 or Motorcraft filter, but I did pickup 12 Advance Auto Total Grip Filter for $.95 each. They are made by Purolator but they only have a nitrile anti-drainback valve, not a silcone one like Ford reccomends. I guess I will stick to the Motorcraft and keep the AAP for my Explorer.
Old Sep 18, 2009 | 01:03 PM
Ministang's Avatar
I've used K&N oil filters in my Bullitt in the past, but just use the Motorcraft oil filters on both Mustangs now. They are inexpensive and readily available at Walmart, and I can buy them on the way home from work at 4am when all other autoparts stores are closed. I use M1 synthetic in the Bullitt, but I'm using Motorcraft semi-syn oil in the '08 GT during the warranty period since the factory calls for more frequent oil changes, and I'd just be throwing good M1 away if I changed it every 6 or 12 months, as I only put a few thousand miles a year on the Mustangs.
Old Sep 18, 2009 | 07:39 PM
GRAYPNY's Avatar
Originally Posted by 825LTRGT
Motorcraft FL-820S
Why?
Old Sep 19, 2009 | 12:00 AM
825LTRGT's Avatar
Motorcraft FL-820S
Why?
A new filter can't hurt. And they are cheap. So am I.
