Oil Filler Breather Help
Old Oct 15, 2010 | 09:22 AM
Originally Posted by colbymh
Pics?? Soo might be a dumb question but why do you get more blow by on the passenger side?
Ive noticed my breather fills up much faster on the passenger side vs driver side. I don't have a CMF oil cap, nor did I really know what it is. lol
You're right. I think thats what I meant. Before the CFM oil breather I had a lot of oil coming from the passnger side breather. It would pool in the #2 cylinder coil/plug well. Now its stopped after installing the CFM. I'll get pics for you tonight. But the driver side breather is bone dry compared to the passenger side.
Old Oct 15, 2010 | 12:48 PM
Someone call my name?
No need to pull the camcover to remove the oil filler neck.
In my FI application, I still get oil seepage onto my camcover in the same area as Gary described (though not as much as before getting the CFM), and I have both the CFM and K&N breathers.
Old Oct 15, 2010 | 06:09 PM
classix_stang289's Avatar
well i tried what was suggested before as far as removing the cap and installing it. never knew it worked both ways like that, but it did. so now its on with the stock neck still in place and im going to leave well enough alone. thanks again!
Old Oct 16, 2010 | 06:01 AM
Dixie_Flatline's Avatar
Glad you got it to work, John.
How often do you guys clean your breathers?
Old Oct 16, 2010 | 06:09 AM
i need to get an idea on this as well, i just put the K&N Pcv breathers on last week and the oil filler yesterday so everything is still clean as a whistle. Maybe check them every week or two, does it depend on how hard you drive your car plus your modifications to the car?
Old Oct 16, 2010 | 01:21 PM
colbymh's Avatar
Where are u guys getting the k&n breathers and how much? Im spending $9 each but im still lost about the oil filler part. Link/pics?
Old Oct 16, 2010 | 02:53 PM
goy my K&N Breathers from amazon
Passenger side- 3/8 breather part number 62-1320
Driver side- 5/8 breather part number 62-1340
As far the oil filler breather, thats if you are getting too much blow by from the passenger pcv or if you just want to do the mod. Are you asking where to get one from or how to install? As far as where to get one, google Central Florida motorsports and they have the oil filler breather filter attachment. As far as how to install one without removing the stock filler neck, removing your oil cap and set it aside. screw in the silver looking attachment(peice with o-ring gasket), then install filter on top and tighten down. Kudo's to dixie for pointing this out to me!
EDIT: http://focus.c-f-m.com/ this is the website. go with the one that is 2005-11 specific, not the one that says 1986-2011.
Old Oct 16, 2010 | 04:28 PM
colbymh's Avatar
Ahhh thank u.
So this one?
http://focus.c-f-m.com/cfmbilletvalv...mustanggt.aspx
Old Oct 16, 2010 | 04:30 PM
colbymh's Avatar
You can pull the filler neck from cam case tho vs screwing part into neck right?
Old Oct 16, 2010 | 07:40 PM
the same way that the oil cap screws on to the neck is the same way the neck screws into the cam cover, same style. Its just i chose to leave the neck on due to too many people telling me there is a clip in there. So instead of doing something i may regret if there indeed IS a clip in there, i took the easier safer way out.
Old Oct 16, 2010 | 10:43 PM
colbymh's Avatar
Wow $20 bucks a side. Since i cant think of any performance issue i think ill stick to paying $8 for the identical ones at auto zone.
Old Oct 17, 2010 | 08:01 AM
yea man plus whatever you use no matter the ones from auto zone or K&N and the oil filler breather, everything feels so much smoother.Who knows, might even gain some ponies from this. Should of done this sooner.
Old Oct 17, 2010 | 10:11 AM
colbymh's Avatar
Ive seen first hand how much oil gets sucked into the manifold so ya the delete mod with breathers was a no brainer for me.
Im anxious to get the cfm unit tho to limit the excessive blow from the passenger side.
Old Oct 17, 2010 | 11:44 AM
keep us updated if you need any help with it when you get it.
Old Oct 25, 2010 | 05:50 PM
colbymh's Avatar
Okay got it in the mail today. Took all of about 25 seconds to install it. The oil filler neck comes off easy after lifting the tab..twist counter clockwise and done.
Anyway..Here is the install..Lil dirty under the hood, but crappy weather for the last week will do that.
Old Oct 25, 2010 | 05:51 PM
colbymh's Avatar
Old Oct 25, 2010 | 05:52 PM
colbymh's Avatar
Old Oct 25, 2010 | 05:53 PM
colbymh's Avatar
dblhelx
Oct 6, 2015 08:08 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
