Nice Informative Article
Old 9/14/04, 03:33 PM
CarlsV6's Avatar
Hope this ain't a repost, I just noticed it today and didn't yesterday.
http://media.ford.com/products/press_artic...1052&make_id=92
Old 9/14/04, 03:42 PM
Willfulone's Avatar
Is that official pricing???
Peace
Willfulone
Old 9/14/04, 03:50 PM
freebass55's Avatar
Check out the Sticky
Old 9/14/04, 03:54 PM
charles's Avatar
cool i think we have prices
Old 9/14/04, 03:56 PM
freebass55's Avatar
Check out the Sticky!
Old 9/14/04, 04:13 PM
CarlsV6's Avatar
The COMPLETE official prices are already in the sticky up top. This just had some other good stuff in it as well as specifications.
Old 9/14/04, 04:14 PM
CarlsV6's Avatar
Specifications
DIMENSIONS AND CAPACITIES
Length 187.6
Width 73.9
Height 54.5
Wheelbase 107.1
Track, f/r 62.8/63.0
Fuel capacity 16 gal
Oil Capacity
GT 6.0 qt
V-6 5.0 qt
Coolant capacity 12.5 qt
INTERIOR
SAE passenger volume (cu ft) 98.0 cu ft
Cargo volume (cu ft) 13 cu ft
Headroom 38.6
Legroom 42.7
Hiproom 53.6
Shoulder room 55.3
POWERTRAIN
Engine Type
GT 4.6L 90-degree V8; aluminum block, and heads
V-6 4.0L 60-degree V6; iron block and aluminum head
Bore x stroke
GT 3.55 x 3.54
V-6 3.95 x 3.32
Displacement
GT 281 cu in, 4606 cc
V-6 246 cu in, 4009 cc
Compression Ratio
GT 9.8:1
V-6 9.7:1
Fuel Injection
GT Electronic returnless sequential
V-6 Electronic returnless sequential
Valvetrain
GT SOHC, 3 valves per cylinder, variable camshaft timing
V-6 SOHC, 2 valves per cylinder
Power
GT 300 hp @ 5750 rpm
V-6 210 hp @ 5250 rpm
Torque
GT 320 lb-ft @ 4500 rpm
V-6 240 lb-ft @ 3500 rpm
Transmission
STANDARD
GT 5-speed manual (Tremec 3650)
V-6 5-speed automatic (Tremec T-5)
OPTIONAL
GT 5-speed manual (5R55S)
V-6 5-speed automatic (5R55S)
Final drive ratio
GT (Tremec 3650) 3.55:1
GT (5R55S) 3.31:1
V-6 (Tremec T-5) 3.31:1
V-6 (5R55S) 3.31:1
Gear ratios:
(Treme 3650)
(5R55S)
V-6
(Tremec T5)
V-6
(5R55S)
I
3.38:1
3.22:1
3.35:1
3.22:1
II
2.00:1
2.29:1
1.99:1
2.29:1
III
1.32:1
1.54:1
1.33:1
1.54:1
IV
1.00:1
1.00:1
0.00:1
1.00:1
V
0.68:1
0.71:1
0.68:1
0.71:1
SUSPENSION
Front
GT Reverse-L independent MacPherson strut
34 mm tubular, stabilizer bar
V-6 Reverse-L independent MacPherson strut
28.6 mm tubular, stabilizer bar
Rear
GT Three-link solid axle with coil springs, Panhard rod,
22 mm solid stabilizer bar
V-6 Three-link solid axle with coil springs,
Panhard rod
STEERING
Type rack-and-pinion with power assist
Overall ratio 15.7:1
Turning circle, curb-to-curb 36.0
BRAKES
Front
GT 12.4-in vented disc
V-6 11.5-in vented disc
Rear 11.8-in vented disc
Assist type
WHEELS AND TIRES
Base wheel and tire
GT 17-in wheel, P235/55ZR17
V-6 16-in wheel, P215/65XR16
Largest tire available 17-in wheel, P235/55ZR17
WEIGHTS
Base curb weight (lbs)
Manual
GT 3450
V-6 3300
Automatic
GT 3500
V-6 3345
Max towing capacity, properly equipped (lbs)
yabutt
10/23/15 01:05 PM
Antigini-GT/CS
10/5/15 09:43 AM
10/2/15 01:00 PM
FordOfMurfreesboro
9/29/15 02:19 PM
Evil_Capri
Motorsports
9/11/15 08:04 PM
Quick Reply: Nice Informative Article
