Hope this ain't a repost, I just noticed it today and didn't yesterday.
http://media.ford.com/products/press_artic...1052&make_id=92 |
Is that official pricing???
Peace Willfulone |
Check out the Sticky
cool i think we have prices
Originally posted by freebass55@September 14, 2004, 2:53 PM Check out the Sticky |
The COMPLETE official prices are already in the sticky up top. This just had some other good stuff in it as well as specifications.
Specifications
DIMENSIONS AND CAPACITIES Length 187.6 Width 73.9 Height 54.5 Wheelbase 107.1 Track, f/r 62.8/63.0 Fuel capacity 16 gal Oil Capacity GT 6.0 qt V-6 5.0 qt Coolant capacity 12.5 qt INTERIOR SAE passenger volume (cu ft) 98.0 cu ft Cargo volume (cu ft) 13 cu ft Headroom 38.6 Legroom 42.7 Hiproom 53.6 Shoulder room 55.3 POWERTRAIN Engine Type GT 4.6L 90-degree V8; aluminum block, and heads V-6 4.0L 60-degree V6; iron block and aluminum head Bore x stroke GT 3.55 x 3.54 V-6 3.95 x 3.32 Displacement GT 281 cu in, 4606 cc V-6 246 cu in, 4009 cc Compression Ratio GT 9.8:1 V-6 9.7:1 Fuel Injection GT Electronic returnless sequential V-6 Electronic returnless sequential Valvetrain GT SOHC, 3 valves per cylinder, variable camshaft timing V-6 SOHC, 2 valves per cylinder Power GT 300 hp @ 5750 rpm V-6 210 hp @ 5250 rpm Torque GT 320 lb-ft @ 4500 rpm V-6 240 lb-ft @ 3500 rpm Transmission STANDARD GT 5-speed manual (Tremec 3650) V-6 5-speed automatic (Tremec T-5) OPTIONAL GT 5-speed manual (5R55S) V-6 5-speed automatic (5R55S) Final drive ratio GT (Tremec 3650) 3.55:1 GT (5R55S) 3.31:1 V-6 (Tremec T-5) 3.31:1 V-6 (5R55S) 3.31:1 Gear ratios: GT (Treme 3650) GT (5R55S) V-6 (Tremec T5) V-6 (5R55S) I 3.38:1 3.22:1 3.35:1 3.22:1 II 2.00:1 2.29:1 1.99:1 2.29:1 III 1.32:1 1.54:1 1.33:1 1.54:1 IV 1.00:1 1.00:1 0.00:1 1.00:1 V 0.68:1 0.71:1 0.68:1 0.71:1 SUSPENSION Front GT Reverse-L independent MacPherson strut 34 mm tubular, stabilizer bar V-6 Reverse-L independent MacPherson strut 28.6 mm tubular, stabilizer bar Rear GT Three-link solid axle with coil springs, Panhard rod, 22 mm solid stabilizer bar V-6 Three-link solid axle with coil springs, Panhard rod STEERING Type rack-and-pinion with power assist Overall ratio 15.7:1 Turning circle, curb-to-curb 36.0 BRAKES Front GT 12.4-in vented disc V-6 11.5-in vented disc Rear 11.8-in vented disc Assist type WHEELS AND TIRES Base wheel and tire GT 17-in wheel, P235/55ZR17 V-6 16-in wheel, P215/65XR16 Largest tire available 17-in wheel, P235/55ZR17 WEIGHTS Base curb weight (lbs) Manual GT 3450 V-6 3300 Automatic GT 3500 V-6 3345 Max towing capacity, properly equipped (lbs) |
