NEW Engine in 09
As good as that sounds, really there comes a point where it's overkill. What I mean is, if the 300 hp 4.6 isn't enough, you can pump it up to run over 500hp fairly safely. That kind of power on the street is enough to satisfy most urges.
I guess the hard core racers will appreciate it more, but to me the Mustang is al about a blank canvas to modify.
I'm not sure what your are getting at here, because they do exactly that in V-8 trim. I'm also surprised at the number of people waiting for the Boss to show up as an OHV design. I think it is pretty telling that the only reference to an OHV design for that motor has come from the mouths, and key-boards, of those who would like to see one and not any of the leaks.
Sonic Blue: I'm suspecting that the clutches aren't "bad", its just that they may need a bit more friction modifier to quiet down. I also suspect the S197 GTs are getting the 03-04 Cobra carbon fiber clutches from the factory, which should be a LOT grippier than the standard clutches on the T-Lok. I'd try more FM before ditching a tried-and-true LSD.
Fuel tank slow to fill
Axle howl / moan
Sound while turning at low speeds
Smart Junction Box failure due to possible leakage
Water entering passenger compartment possibly through grommets
Erratic fuel gauge behavior (probably supplier issue, since 07 Focus has same TSB)
dash rattling
and other minor problems
Axle howl / moan
dash rattling
Evil_Capri
9/11/15 08:39 AM
