Need help! Brake fluid tank ran empty.
I recently install a stoptech brake kit bought used from a forum member. One of the bleed screw's was cross thread by the previous owner. The thread was stipped and brake fluid was leaking everywhere so I reattached the old caliper to the lines and left it hanging in the mean time to repair the stoptech caliper.
When I came home today to check the brake fluid tank and it was empty. Holy crap. Am I in a big mess?
Stoptech says in the install manual that if the brake reservoir runs empty and draws in air. That the brake system would need to be service by a certified brake techician. Is that true? or could I just put in more brake fluid and rebleed the whole kit again until all the air is out?
Any help is appreciated as I am panicing right now. Thanks.
oh cool, thanks for the info. I thought it was something more technical that happen if the reservoir runs dry. Guess not. I was getting worried there for a second. I can bleed the system myself. Thanks again.
Crap. You really have to bleed the abs system? I have no clue how to do that. I didn't know the abs system was link to the brake lines. Does anyone know if this is true?
I read somewhere that some system with a good bled with do the job and there would be no need to do the abs. Some you will need to bled the abs. Which system is our mustang? Also how is the brake lines from the abs link to the regular brakes lines?
It states in the service manual that if you get air in the lines, you will need to run a service procedure (hooked up to the IDS system that we can't get) to properly bleed the ABS system.
That's what it states.
But, I did NOT have any issues getting everything to work correctly (brakes and ABS) with just a mostly standard bleed. I did to a power bleed on it (Pressure tank pushing pressurized fluid into the reservoir) versus the "pump and hold" bleed, but I do not know if that made any difference or not. I WILL say that little "Motive Pressure Bleeder" kit is MORE than worth it to me! The one you need for 2005+ Mustangs is: http://store.motiveproducts.com/shar...unt2=891624093
Good luck.
Good luck.
If it was a front caliper that was leaking and you haven't touched the brake pedal yet you might get by with just refilling the resevoir and letting it gravity bleed from the caliper that was leaking. If it doesn't work you'll have to bleed the system.
Also does anyone know if the ABS line is link to the regular brake lines? Does anyone know how to bleed the ABS system?
I tested mine the old fashioned way: I hammered the brakes from medium speed. The racket the ABS systems makes is VERY clear. I tested on clean asphalt roads as well as looser roads to see if the ABS was activating, did the car brake straight, or did it pull to one side or the other, was one wheel locking up, could I turn while braking hard with the ABS activated without loosing control due to wheel lockup, etc. Fairly basic driving tests.
Unless you have a $4000 VCM/IDS system, you can't bleed the ABS system. That system is used to active the pump and open and close the valves automatically in a bleeding routine. That puts it pretty much out of our league, unfortunately.
Actually, it is somewhat possible to bleed the ABS, you need to get it to activate several times while driving to operate the valves, then bleed the regular brakes again. If your pedal goes soft after an ABS activation, then you had air in the ABS module and need to bleed the brakes again.
Good luck.
Good luck.
