Low oil pressure
Has anyone else had a problem with your oil pressure gauge? Sometimes when I start the car the oil pressure gauge has no reading, an "oil pressure low" message comes up on the message center and the oil gauge itself turns red. Maybe 3 seconds later the messages and warnings go away and the gauge gets a reading.
Bueller?
Bueller?
Well it does take a second for any car to begin pumping the oil back up, so really there is little pressure on startup, then it'll get normal.
As long as it always goes away, there should be no alarming.
Originally posted by sodaman@May 6, 2005, 3:12 AM
Either way have dealer check out. SO it is on paper etc. In case you have any issues down the road , it will be documented. Good luck
Bueller?
Bueller?
Originally posted by black gt 2005+May 6, 2005, 7:01 AM--><div class='quotetop'>QUOTE(black gt 2005 @ May 6, 2005, 7:01 AM)</div><div class='quotemain'><!--QuoteBegin-dustindu4@May 5, 2005, 11:04 PM
Bueller?
Bueller?
[/b][/quote]
The language filter strikes again! It was a legitimate use of the "suction" word and it got changed to "stinking".
