Loose outside door handle
Old Aug 27, 2007 | 11:44 PM
DoctorQ's Avatar
I've noticed my driver's outside door handle is slowly becoming loose... it seats and functions fine...but front part of the handle (facing from of car) is now slightly loose and can be jiggled. The passenger handle is nice and tight (I suspect from less frequent use). Question: is there semi-easy fix to tightening up this loose play... or will this require the dreaded dealer warranty visit... Thx all.
Old Aug 28, 2007 | 01:20 AM
ShowGT's Avatar
Let your dealer replace the handle.
Old Aug 28, 2007 | 05:11 AM
Lime GT's Avatar
Try this post by LimeGT. http://forums.bradbarnett.net/showthread.php?t=44694 It worked for my car also. It might be what your describing.
Old Aug 28, 2007 | 06:58 AM
JonCo's Avatar
same thing happened to mine. Dealer replaced the entire thing.
Old Aug 28, 2007 | 11:52 AM
Ranger's Avatar
Also had the issue on the driver's side. It appears to me that, at least from members of TMS, this problem is more than just minimal but there is no TSB on it. Not sure what, if any, guidelines Ford uses before a TSB or other info is issued.
Old Aug 28, 2007 | 12:48 PM
DoctorQ's Avatar
just curious... left on it's own, does it continue to get worse (or even fail).. or just remain slightly loose & rattle?
RCooke08GT
Feb 19, 2017 03:03 AM
ricky1728
Feb 11, 2016 07:25 PM
GeoWett
Sep 30, 2015 06:40 AM
