lights turning on/off
Anyone had this happen?? I'm working, drive by and see my fog lights and tail lights on. wtf, I say to myself. turn around, pull up next to it. its all locked up and while i was standing there, they turned on/off again.
i turned the car on/off and havent seen it happen again, but im wondering what the h#ll would make that happen.
I came out to the garage on several occassions and started the car only to have the "trunk ajar" message. WTF?? I finally figured out I had hit the keyfob in my pocket while I was inside the house.
I wonder if something similar could be happening? Since you have an '08, the headlights turn on when you hit the lock button right?
Check your passenger side floor board and feel around in there. Sounds like the water leak issue some people have experienced that causes erratic electrical problems.
I did check and it was dry as a bone. I took a few photos and added them to a thread in the warranty/issues forum. I dunno..Guess I will have to keep an eye on it.
I will be pi$$ed off if it is leaking. my 75 CJ5 didnt leak with a soft top, so this d@mn thing better not.
My Smart Box problems due to cowl water leak (fixed by my dealer prior to the roll out of the TSB) resulted in only a single tail light bulb (not the entire tail-light unit) or a single front marker light staying on with the car off and all other lights off. Never were all the bulbs in a unit or both sides on at the same time but I guess anything is possible.
If the fogs and tails flash with lock/unlock on the 08's (or an aftermarket alarm if you have one), I'd lean toward inadvertent key fob activation in a pocket.
What are the chances of cross frequency activation from an unrelated remote? My Bose remote used to activate my neighbor's Bose system...
9/8/15 10:45 AM
