Leaking Brakes
Old May 21, 2007 | 10:05 AM
B00ST's Avatar
Question Leaking Brakes
Okay...I'm an idiot...at least I think. Changed Rotors and Pads yesterday. When I went to bleed the brakes, I noticed that the line to the rear caliper was leaking...(must be not tight enough)...So I tighten...nothing - still leaking. Pull it off, clean thoroughly...put back on - leak...did this a number of times with the same issue....WTF did I do now!!!??? HELP
And Yes, I did remove the calipers from the car...just made it easier...(at least I thought)
Old May 21, 2007 | 10:53 AM
frdtch05gt's Avatar
Did you install new brass washers on the banjo bolt for the brake line? Those washers are usually one time use.
Old May 21, 2007 | 11:01 AM
B00ST's Avatar
Nope...that's my thinking as well. Just went to the dealer and bought a set (actually 2 - just in case)....
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
