Leaking axle???!!!
Old 1/6/10 | 07:21 PM
06GT's Avatar
Originally Posted by Stoenr
Must have been that thin air in CO!
I never noticed mine leaking on track days, hmm, maybe I need to drive it harder!
Didn't happen to me until the first time I put Hoosiers on
Old 1/7/10 | 07:52 AM
CO_VaporGT_09's Avatar
Update:
Got the item shipped a few weeks ago, not quite the quality I was hoping for, and no instructions included, but seems simple enough. I'll post some pics when I get the chance (though not installing it until I can touch the concrete without freezing -- negative eight in Denver this morning).
Old 1/7/10 | 08:34 AM
Doogie's Avatar
FYI... the install instructions are available from the Shelby store listing http://www.teamshelby.com/shelbystore/docs/tkr1.doc
Old 1/7/10 | 09:55 AM
06GT's Avatar
In for pics of install...
Old 1/12/10 | 11:19 AM
06GT's Avatar
Mine arrived yesterday...may have the chance to install this weekend.
Old 1/12/10 | 09:55 PM
06GT's Avatar
Put the overflow tank in tonight, got it done on jackstands, without removing the exhaust or mid pipes; had to wiggle the tank in between the pass side pipe and the diff; tight fit but it made it.
Here are some pics; would have done a "Taco-Bill" write up but I was getting pretty annoyed crawling around under the car w/ limited breathing room. This would be much easier/faster on a lift.
From directly underneath:
From rear and below, shows the locations of the bolts you will use (right side one comes w/ the breather). This will be pretty obvious once you get the tank mocked-up in place.
Final shot showing orientation of the axle fitting.
I backed out the axle fitting about 1/4 turn from "tight" as I didn't want to crush the hell out of the o-ring. We'll see if it leaks during the next track day...it can always be tightened. I pointed the fitting slightly towards the front of the diff so the hose will (cleanly) clear the axle tube when the suspension is compressed.
Additional notes:
  1. The brass fitting on my kit was pretty difficult to get into the axle fitting. Initially I thought it might be cross-threading, but it looked fine when I took it apart. I ended up joining the two off of the vehicle using a 9/16" wrench and a 1/2" wrench. I doubt more than 3-4 threads actually engaged. Threadlocker was used.
  2. The factory axle fitting was a 15mm on my car (06 GT), not a 13mm as noted in Shelby's instructions.
  3. I didn't use the supplied Zip Tie, my evaporator tube is not close to the tank and there is no fear of contact/rubbing.
Old 1/13/10 | 08:04 AM
Cool! Thanks for the notes and the pics, should make my install much easier!
Thought I'd get to the first track day in April, but not happening, so I won't be needing it installed til May. Still have my upper 3rd link to install, so hopefully will get it all done on a day when the concrete isn't freezing (I would love having a lift, too).
Old 1/13/10 | 08:18 AM
Good job with the documentation, I'm sure it'll help other members thinking of doing this mod.
Gill5oh
10/6/17 10:50 PM
09-gt/cs
10/15/15 10:03 AM
Rando
9/30/15 12:28 PM
9/24/15 08:15 PM
Quick Reply: Leaking axle???!!!
