Jump start...now no TCS or ABS
Old Aug 6, 2006 | 08:36 PM
mbkintner's Avatar
I used my 2006 GT to jump start my 2004 Suburban......I'll pause here for everyone to chastise me...........
So anyway, everything seemed to go fine but now the TCS Off light is on and the ABS light is on. I'm hoping it's a fuse but it's too late to check tonight. I'll look tomorrow afternoon but in the meantime has anyone had a similar experience?
Mike
Old Aug 6, 2006 | 08:56 PM
lnmech's Avatar
had the same prob but didnt jump a car.could be two things 1.abs module bad or 2.bad ground.its ground 101.ill check for location for you.
Old Aug 6, 2006 | 09:03 PM
mbkintner's Avatar
I did a search before posting and came across your post regarding the ABS module and the ground issue. I'd be surprised if my issue was a ground problem, to coincidental after the jump start but please do check the location of your ground issue. Any info is good info.
I suppose jump starting could have taken out the ABS module but I would hope that the car isn't that sensitive.
Mike
Old Aug 6, 2006 | 09:31 PM
lnmech's Avatar
if this helps its on the drivers side looks like in front of the airbox.it is in that area.another person had the same prob and it was the ground.after they replaced my module they messed up and did not tighten the ground good.hope this helps let me know.
Old Aug 7, 2006 | 06:47 AM
Mark S.'s Avatar
Sorry to hear about that...hope you can resolve this...but for next time, go ahead and buy one of those small $30 portable 12V systems to keep on hand and use that instead...keep us posted.
Old Aug 7, 2006 | 08:20 PM
mbkintner's Avatar
Well it's fixed, don't really know how or why but it's fixed none the less. I had the exact same lights this morning when I started the car; TCS Off, ABS, and the car with squiggly lines. About 3 to 5 minutes down the road they all went out and everything seems to be working fine again. I'll have to find a wet spot on the road to really test the ABS and the TCS but the lights are out and the TCS On/Off works. While I'm glad it's working I kind of hate it when something is "broke" and then starts working. You never know what caused it so you never really know if it's "fixed".
Old Aug 7, 2006 | 08:50 PM
Mark S.'s Avatar
Well, count your lucky stars and I wouldn't use your GT to jump start any other cars...
Old Aug 7, 2006 | 08:54 PM
korinwoodo's Avatar
Did you jump it Black to Black and Red to Red? That might have been the problem.
Old Aug 7, 2006 | 09:24 PM
mbkintner's Avatar
Shouldn't have been my method I went:
+ to +
- on the Mustang (good battery) to a ground on the engine block of the Suburban (dead battey)
Old Aug 7, 2006 | 09:58 PM
lnmech's Avatar
i'll bet you its the ground i told you about another guy here was having same thing.he had some one jiggle it while it was running to see if it was the prob.
you should check just to make sure.
Old Aug 8, 2006 | 09:07 AM
korinwoodo's Avatar
Yeah thats the right way. My dad usually does it the stupid way so you never know.
JT_Kwik
Nov 29, 2022 01:45 PM
Uofmrampage
Aug 2, 2022 02:55 PM
boz
Oct 1, 2015 04:47 PM
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
DarrenGT
Aug 19, 2015 08:22 AM
