Issue with power steering pump pulley not fully seated?
Old Apr 12, 2022 | 09:00 PM
patdugan's Avatar
I'm redoing the power steering system on a 07' GT. While installing the pulley onto a remanufactured motorcraft pump, the bolt from the cheap pulley installer kit I purchased broke in half.
It's not quite at flush, but close. Can I get away with leaving this as is rather than buying a new pump and starting over? Any idea what issues this might cause?
Old Apr 12, 2022 | 09:05 PM
patdugan's Avatar
The other half of the installer bolt is still in the shaft of the power steering pump, so as far as I'm aware not possible to get that broken piece back out.
Old Apr 12, 2022 | 10:09 PM
BRD's Avatar
BRD
Just my humble opinion, having the pulleys even just that little bit off, would probably chew up belts like crazy. That sucks that thing broke, not sure if you could go back to the manufacturer of the install tool and they would resolve it or find another way to seat that pulley? I've never done it before, so someone that has some experience may be able to help more or give you an idea.
Old Apr 13, 2022 | 06:15 PM
houtex's Avatar
You need to get that aligned correctly as he says, chewed belt or even more fun a thrown one. And while you could swap it out like you say, the other possible is to drill the bolt out that snapped off. You might can use left hand drills and it back right out, or at least stick a hole in it that you can stick an ez out in and get it out that way.
You can also try a small enough dot of JBWeld or other such amazo 'glue' to stick a bolt down there, let it stick, and then turn the bolt back out, which will extract the broken bit. Or weld that bolt on, but I don't know how... maybe somehow rig up a stick weld with the bolt on the end and stab it on... Not a weldor, just have enough info to suggest stupidness like that.
All these are possibles, mind, suggestions, all up to you to decide if you want to try or not. Time, effort and money considerations are all on your end.
And if you get a new pump, you still have to get the pulley off, or buy a new one, so... yeah, might be worth the effort to quickly try and see what happens.
Hope that helps, and good luck! Welcome to the forums!
curtisboyte
Aug 7, 2011 09:24 PM
Detroit Muscle
Jun 27, 2011 10:09 AM
Rogue
Rocket City Mustang Club
14
Feb 27, 2008 10:49 AM
flamin ponyexpress
Jul 25, 2007 09:07 PM
Cheese302
Oct 4, 2006 09:31 PM
