Intermittent whine during cold starts
Old Apr 1, 2007 | 01:49 PM
G.T's Avatar
G.T
Question Intermittent whine during cold starts
Since i got the H.O whipple installed a little over a week ago, i've started noticing this intermittent whine coming from the engine compartment during cold starts, and last a few minutes till the engine is fully warmed up.
i tried to listen carefully and locate the source of the noise to no avail.
The noise is a medium pitched constant whine, that changes pitch from time to time, and suddenly stops for a few seconds.. returns for a few, then stops completely as the engine fully warms up.
First thing i suspected was the IC electric water pump, but i've heard the sound it makes with the ignition on, and engine off.. and that was more like a light buzz, pretty different than the whine i hear with the engine on.
Please check the video and pay attention to the sound.. it becomes a bit more audible at around 00:25 cuts off for a bit, then returns at 00:42 and so on..
in case the video isn't yet ready or the sound isn't clear enough on YouTube, i've also uploaded the soundtrack as a 192bit MP3
your thoughts please?
thanks in advance!
Old Apr 1, 2007 | 02:08 PM
steevr's Avatar
I listened to the MP3. If I'm hearing it right, it almost sounds as if someone is blowing into a flute.
Old Apr 1, 2007 | 02:18 PM
G.T's Avatar
G.T
yup.. that's it
the pitch does resemble a flat note from a flute
Old Apr 1, 2007 | 02:20 PM
theedge67's Avatar
Sounds like it could be a belt or something.
Old Apr 1, 2007 | 02:31 PM
G.T's Avatar
G.T
i couldn't see any vibration on any of the pulleys, or anything abnormal with the belt
in fact it runs just fine.. just give it a few minutes to warm up and the noise is gone.
usually belt slips sound way different than that.. right?
Old Apr 1, 2007 | 02:37 PM
theedge67's Avatar
Belt slips sound different. I'm not saying it was a belt slip, but the way it comes and goes does sound like a high speed vibration to me, and the only thing I can think of that matches that would be a belt. Other than that it might be something inside the whipple, which I have NO idea how those things insides work, so I'm no help there!
Old Apr 1, 2007 | 02:55 PM
tom_vilsack's Avatar
Sounds like either a belt/bearing or maybe a air leak?
maybe try using a rubber hose to isolate where sound is coming from (least thats what a muffler guy did once with mine)
could it be from here?
Old Apr 1, 2007 | 03:04 PM
G.T's Avatar
G.T
keeping track of my progress?
that's a good guess, but i had the noise before i installed the water temperature sensor there
once she's back from the bodyshop, i'll probably gonna go around the engine compartment with a Doctor's Stethoscope to see where the heck it's coming from!
Old Apr 1, 2007 | 06:39 PM
Lime GT's Avatar
Try to isolate the noise, by using a spray bottle filled with water to spray the belts, pulleys and other parts including vacuum lines, separately, to see if the sound changes.
Old Apr 2, 2007 | 12:51 AM
G.T's Avatar
G.T
Thanks for the tip Lime GT!
Old Apr 2, 2007 | 10:08 AM
mvon919's Avatar
Hey Louie... you have twin screw S/C under hood now... it's normal.
Old Apr 2, 2007 | 02:27 PM
G.T's Avatar
G.T
okay okay.. so i'm stressing over nothing and it's all normal
but where exactly is it coming from?
i love my SC whine, but this is different :S
Old Apr 3, 2007 | 01:04 AM
G.T's Avatar
G.T
Well i sent the video to Whipple..
let's see what they say about it
Old Apr 3, 2007 | 01:27 AM
theedge67's Avatar
Good idea!
Mpaps
Oct 11, 2017 08:06 PM
Rando
Sep 30, 2015 12:28 PM
DrisStang
Sep 14, 2015 06:20 PM
Omegaprime92
1994-2004 V-8
Sep 8, 2015 08:53 AM
