Interior Map Light and A-Pillar Removal Questions
I am finally getting ready to install my Homelink mirror, and just wanted to check and see if there is an easy way to remove the interior map light cover and the A-Pillar trim. I did a search and couldn't find anything specific, and I don't want to break any of those plastic trim pieces. Any help or advice would be most appreciated
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Craig - if you have ever wanted to install footwell courtesy lights.....now's the time. Simply tap into the overhead courtesy light circuit (there are 3 wires IIRC and you want the courtesy light feed - not the map light feed) and run the wires down the A pillar and under the dash. I did this on my '05 and am going to do it on my '07 1st chance I get. On my '05 I used the side marker light (wedge base 194 bulbs) but for the '07 - I'm going to get the lights/sockets for a Lincoln and install them.
Thanks for all the info guys, I just wanted to make sure there weren't any tricks involved, because I didn't want to break any of those plastic trim pieces.
Diode Dynamics
6/12/18 03:26 PM
Diode Dynamics
2/28/18 09:37 AM
