Interior Map Light and A-Pillar Removal Questions
Old Nov 17, 2006 | 09:49 PM
Mustang Buster's Avatar
I am finally getting ready to install my Homelink mirror, and just wanted to check and see if there is an easy way to remove the interior map light cover and the A-Pillar trim. I did a search and couldn't find anything specific, and I don't want to break any of those plastic trim pieces. Any help or advice would be most appreciated
Thanks in advance!
Old Nov 17, 2006 | 10:30 PM
delz05's Avatar
They just pull down with metal snap clips holding them in place. Firm and even pressure will do the trick, then simply un-plug the harness.
Old Nov 18, 2006 | 07:26 AM
dly's Avatar
dly
Go to the web page for Speed of sound I think, It has a video of them removing the a-paller takes about 10 secs. I did it when I install my 3 gauge a pillar set.
dly
Old Nov 18, 2006 | 08:17 AM
HOTLAP's Avatar
Thanks in advance!
Craig - if you have ever wanted to install footwell courtesy lights.....now's the time. Simply tap into the overhead courtesy light circuit (there are 3 wires IIRC and you want the courtesy light feed - not the map light feed) and run the wires down the A pillar and under the dash. I did this on my '05 and am going to do it on my '07 1st chance I get. On my '05 I used the side marker light (wedge base 194 bulbs) but for the '07 - I'm going to get the lights/sockets for a Lincoln and install them.
Old Nov 18, 2006 | 11:12 AM
Thanks for all the info guys, I just wanted to make sure there weren't any tricks involved, because I didn't want to break any of those plastic trim pieces.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
defiance772
Oct 21, 2015 09:37 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Earlsays
Aug 5, 2015 07:10 AM
