How to program keyless entry remote?
Old Nov 13, 2006 | 05:37 AM
t9r's Avatar
t9r
Our 2006 mustang GT just got a new "smart box" because the terminals on the other one were corroded. We got the dealer to program one of our remote transmittors but I thought I could find the info here without having to drive back up to the dealer.
I watched the tech do some of it but missed the last steps in the procedure.
Open drivers door
Hit the unlock switch on the door panel
Rotate key to ON position 8 times
The locks will cycle unlock - lock - unlock
WHAT next? It has something to do with the transmittor but what?
Thank you.
Old Nov 13, 2006 | 10:52 AM
theedge67's Avatar
Check your owners manual. It details it if I remember right...It's amazing what kind of good info there is in there.
Old Nov 13, 2006 | 10:57 AM
theedge67's Avatar
Copied from the Owners Manual, available online at https://web.msslib.dealerconnection....000c588053025a
To reprogram the remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the ignition.
3. Cycle eight times rapidly (within
10 seconds) between the 1
(OFF/LOCK) position and 3 (ON).
Note:
The eighth turn must end in
the 3 (ON) position. The doors will
lock, then unlock, to confirm that the programming mode has been
activated.
4. Within 20 seconds press any button on the remote entry transmitter.
Note:
If more than 20 seconds have passed you will need to start the
procedure over again. The doors will lock, then unlock, to confirm that
this remote entry transmitter has been programmed.
5. Repeat Step 4 to program each additional remote entry transmitter.
6. Turn the ignition to the 1 (OFF/LOCK) position after you have
finished programming all of the remote entry transmitters.
Note: After
20 seconds, you will automatically exit the programming mode. The
doors will lock, then unlock, to confirm that the programming mode has
been exited.
Old Nov 13, 2006 | 12:09 PM
t9r's Avatar
t9r
Thank you
Thank you.
I searched on here first and could not find any information on it. Now it is here for others to find.
Thanks again.
Now I'll check some of the other functions.
Old Nov 13, 2006 | 08:34 PM
SpeedRoush's Avatar
well, it turned out good. I have two remotes and I was able to program the extra remote with the tips above (thanks )...However, it essentially disabled my primary remote?? When I had my jeep i had two remotes and BOTH worked oh well...
Old Nov 13, 2006 | 09:07 PM
MY05GT's Avatar
You should be able to have up to four remotes ( I do, one of the spares in the center console as a trunk release, and one on a shelf in the garage near the back of the car for loading and unloading stuff from the trunk ) and all of them working. When you go through the programming procedure, you MUST use ALL of the remotes in succession, not just the new ones.
Old Nov 14, 2006 | 03:20 AM
IWantMyNewGT's Avatar
Do you have to go through the entire procedure for each remote, or just push any button on each one of the remotes after going through the procedure once?
Old Nov 14, 2006 | 06:21 AM
MY05GT's Avatar
That is listed as step 5. When you get to the part where you push the remote button ( step4 in post #3) you have all four remotes lined up and do one right after the other. ie ... step 4 with remote 1, step 4 with remote 2 etc.
Old Nov 14, 2006 | 08:21 AM
Old Nov 15, 2006 | 04:16 PM
MY05GT's Avatar
I had purchased a couple of PATS key blanks, but never got them cut or programmed. Finally got it done. I now have four complete key/fob sets. The fob instructions are above, here are the PATS key instruction.
If you want to add a key....
**You must have two original keys to perform this procedure. If you only have one key, you WILL have to take it to the dealer to get it programmed**
1. Insert and existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
6. To program additional keys, repeat steps 1 through 5
NC14GT
Sep 10, 2017 04:47 PM
Fedupdave42169
Oct 20, 2015 10:29 PM
dave07
Oct 8, 2015 03:14 PM
Sep 30, 2015 07:02 PM
Sep 8, 2015 10:45 AM
