How do I clean under hood of 2005?
Old Aug 23, 2010 | 07:31 AM
MUSTANGLOVER73's Avatar
Hey guys, I just got a 2005 mustang that was converted from a V6 to a V8 and the car is really dirty under the hood from the swapping of engines( apparently the previous owner didnt care about this as much as I do). I want to use engine cleaner to clean it up a little (its very dusty/dirty to my liking). Is there anything that i cant get wet when i do this or do you suggest a better way? Also he used "hi temp" paint to paint the fuel rails, valve covers, throttle body etc and it is flaking pretty bad. How should i attempt to clean this up? Thanks!
__________________
Old Aug 23, 2010 | 05:13 PM
Imatk's Avatar
A picture would help, but I would suspect with the paint there's not much to do other than either re-paint it or remove the rest of it.
I like simple green for an all-purpose cleaner/de-greaser. I also like to use no-touch tire shine on rubber, it does a nice job of cleaning and shining.
You can use a hose, just make sure you don't spray it liberally in there. Just use enough to rinse away what you've cleaned.
The best way to clean it really is good old elbow grease and a lot of simple green. That's how I'd do it
Old Aug 24, 2010 | 04:38 AM
how is the best way to remove the paint?
Old Aug 24, 2010 | 11:23 AM
Imatk's Avatar
I would use mineral spirits but do a test section first to make sure it doesn't damage anything beneath.
Old Aug 24, 2010 | 06:21 PM
Green96GT's Avatar
take it to a detail shop and have them steam clean it
May 3, 2026 05:42 AM
Road_Runner
Sep 2, 2024 04:46 PM
yabutt
Oct 23, 2015 01:05 PM
