Hood struts
Hood struts
So I finally bought those nice hood struts from American muscle. I installed them Friday and I guess I don't know my own strength. While attaching the hardware to the fender using existing bolts, I tightened it so hard the bolt sheared and left half in the fender. Anyone have this problem? Anyone know how to get it out? The kit did not come with new bolts as it should. You're adding a 1/4" thick strut mount to the fender and hood. Longer bolts should've been supplied. If you get these I highly suggest longer bolts. Any help is appreciated.
Alternatively, this might work.
http://m.target.com/p/as-seen-on-tv-...w&gclsrc=aw.ds
I've never used it though.
They install in 2 minutes per side, hold the hood up much more firmly especially during windy weather, and you don't have to undo any hood mounting bolts to install them.
This is when I first had the MMD ones installed, you can see the brackets that mount to the fender are kinda coming apart from the fender.
Ended up fixing the problem by switching brackets from side to side:
You should have bought Redline's hood struts. They way they mount I feel is much better. I can open the hood with a finger and the wind doesn't blow it closed.
But back to your problem. Buy a screw extractor kit and new bolts. Should be easy.
Have to drill out and extract. I know this thread is old did you get bolt out?
Are those the ones marked ford performance? I got a set last month and same thing base plate moved around. Got some thread lock and redid pass side no prob, when tightening the drivers side … snap!
SilverSkoundrel
05-09 Exterior Modifications
36
Apr 14, 2019 12:57 PM
SteelTownStang
May 23, 2010 06:08 PM
