help... car wont start
Old Mar 9, 2008 | 10:54 AM
smc99007's Avatar
Everything was fine last night... now im not getting much juice and after a few seconds when i do get some it gives me the "check brake system" code... i charged the battery, but its still doing the same thing... i even disconnected the battery hoping it would restart the comp, but no luck. any ideas??
Old Mar 9, 2008 | 02:03 PM
DarkFireGT's Avatar
Sounds like the battery is not taking a charge. I would suspect your battery is shot.
Old Mar 9, 2008 | 08:44 PM
theedge67's Avatar
Does it crank over quickly, like it usually does? Or does it crank slowly and weak sounding? If it is weak sounding, try a jump start and see if that helps. If so, your battery is probably in the crapper.
Old Mar 9, 2008 | 09:28 PM
Mydnyghte's Avatar
When my car would not start, it ended up being the spark plugs. Cleaned those things up and then the car roared to life like it always did.
Old Mar 10, 2008 | 05:23 AM
do you hear the fuel pump when you turn your key to the on posistion?
Old Mar 10, 2008 | 06:41 AM
smc99007's Avatar
i ended up taking the battery out and charging it up again and got it to turn over... everything seemed fine, but then my parking light on the pass side would not shut off or work as a signal... weird, so its at the dealership right now... if that light doesnt shut off im sure the battery will be drained again soon enough.
adrenalin's Avatar
Do you have any mods such as a tune or CAI?
Old Mar 10, 2008 | 06:42 AM
adrenalin's Avatar
Ah, never mind my question. Sounds like you have some sort of electrical problem.
Old Mar 10, 2008 | 10:27 AM
Mark S.'s Avatar
Well...what year is your Stang? Is the battery original?...your profile says nothing...need to tell us a little something about yourself and your vehicle...
Old Mar 10, 2008 | 10:31 AM
jacostang's Avatar
Sounds like the Battery is wiggin out!
Old Mar 12, 2008 | 04:29 PM
RRRoamer's Avatar
I vote battery. The smart junction box controls all the electrical systems on the car and it freaks out when the voltage gets low. The first time it did it to me, I thought the car was either possessed, or the ECU had completely fried. Just a low battery!
Old Mar 12, 2008 | 04:37 PM
LEO_06GT's Avatar
I had a problem with my car not starting a few months back. Ended up being my starter.
Old Mar 13, 2008 | 07:58 AM
smc99007's Avatar
turns out i did need a new battery... never had one die within 2 years before... but at least it was still under warranty
on a side note, what is this silver piece i have circled in the pic?? it was clicking like crazy when i was trying to start it that day... im guessing its the starter??
Old Mar 13, 2008 | 08:22 AM
runningwild4.6's Avatar
thats your drive by wire throttle motor
Old Mar 13, 2008 | 01:34 PM
jcopin's Avatar
thats what turns the throttle plate on the throttle body when you hit the gas in place of the old wire that used to physically be connected to the pedal.
Ecostang
Nov 3, 2022 08:50 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
goocher625
1994-2004 V-8
Jul 15, 2015 08:08 AM
aphaynes
Rocket City Mustang Club
Jul 9, 2015 09:25 AM
