gt vs g35
Old Apr 18, 2011 | 09:53 AM
zcgstang's Avatar
gt vs g35
Not sure where this should be posted so I apologize but out of curiosity who would win?
I drive an 06 gt with 93 tune Cai and axle backs. He drives an 04 g35.
Who would win??
Old Apr 18, 2011 | 12:28 PM
conv_stang's Avatar
um you should....300+ hp & 300+ Tq Gt versus 2004 G35 with 260Hp & 260 Tq
Old Apr 18, 2011 | 01:41 PM
zcgstang's Avatar
Both of which are manual. But a g35 ways much less
Old Apr 18, 2011 | 02:20 PM
Ministang's Avatar
A G35 doesn't weigh that much less than an early S197 Mustang GT. You didn't say if your friend's G35 was a coupe or sedan, but the curb weight for a 2004 G35 Sedan is 3336 lbs according to Edmunds, although options can take it a lot higher than the base curb weight. Curb weight on a 2006 Mustang GT starts out at 3488 lbs, and goes up depending on options. If you want to even up the weight disadvantage, run with 1/4 tank of gas and no spare tire. The extra torque and horsepower of the Mustang should make it the winner without too much question, although variables like the driver and what tires are on each car can have an impact on the actual results too.
Old Apr 18, 2011 | 02:38 PM
slidejob's Avatar
G35's & Z cars are easy pickings!!
Old Apr 18, 2011 | 06:08 PM
zcgstang's Avatar
Its a coupe with high millage. If that helps with the results. Thanks everyone. He's been trying race ever since I got my strange lol time to finish it
Next instant.. 2011 comaro SS with 20's or my Stang??
Old Apr 18, 2011 | 06:34 PM
Gtpony325's Avatar
The camaro has more horsepower than your mustang. Ive raced a few and i beat them all but my car is not stock. Ive seen the camaros walk all over the s197 stangs but it depends on the driver and tires and all the usual stuff. But stock vs stock the camaro should win.
Old Apr 18, 2011 | 07:27 PM
zcgstang's Avatar
That's what I told my friend. If I had better tires and maybe some suspension work. Basically a way to get the power to the ground I might have a chance.
Old Apr 19, 2011 | 05:59 AM
Gtpony325's Avatar
Im putting 337 to the ground with stock suspension and a set of sumitomos for tires. If the camaro didnt fall of its face off the line im not sure that i could beat it but as long as i leave first i can usually take it unless i miss a gear. Which rarely happens.
Old Apr 19, 2011 | 06:26 AM
zcgstang's Avatar
I envy those numbers lol
Old Apr 19, 2011 | 08:15 AM
Gtpony325's Avatar
It took alot of time and money to get those numbers. Should be more at the ground next year when i do my eibach suspension and ported heads.
Old Apr 19, 2011 | 08:26 AM
zcgstang's Avatar
I'd imagine. From what I've read on this forum its tough to stay n/a and make power. If all goes to plan I should have the extra money for cmdp and udp.
Old Apr 19, 2011 | 08:32 AM
Gtpony325's Avatar
You might be able to save some
Money on the delete plates if you modify your stock motion plates. I pulled the blades out of mine and welded the holes shut and smoothed them out. Then had them powdercoated the same color as my car. Only cast me about $100 to have the holes welded and smoothed out. But i am fortunate enough to know people that can weld those. Just and idea of something you could look into.
Old Apr 19, 2011 | 09:02 AM
zcgstang's Avatar
IV been checking sites periodically hopping to find someone who is selling there's cause Idk how to weld lol
Old Apr 19, 2011 | 09:45 AM
Barricade's Avatar
How much HP will the delete plates get you?
Dont you need a tune to take advantage of that??
Old Apr 19, 2011 | 09:53 AM
zcgstang's Avatar
10 or so from What IV read but yes you do need a tuner with a proper tune.
Old Apr 19, 2011 | 11:24 AM
Gtpony325's Avatar
They say up to 15 hp with the delete plates. If i had to guess i would put it at maybe 8-10 hp. And you will need a tune or you will constantly have a check engine light for the motion plates being stuck open or something like that. It seems that almost anything that you do to the s197 requires a tune.
Old Apr 19, 2011 | 02:35 PM
zcgstang's Avatar
Haha it does seem that way...
FromZto5
75
Oct 5, 2015 02:27 PM
Hollywood_North GT
27
Sep 17, 2006 09:11 PM
cyoon
Sep 5, 2005 07:21 PM
Fazm
Which is Better
Apr 17, 2005 04:44 PM
vroomvroom
Which is Better
Jan 17, 2005 11:14 AM
