Fuel Filter Replacement
Old Jan 4, 2013 | 07:48 AM
NC14GT's Avatar
How often do you change your fuel filter? Do you go by miles or the age of the filter? I'm still on the original but only have 10,000 miles. Do they go bad by age alone?
Old Jan 4, 2013 | 08:09 AM
shurtual86's Avatar
Edit: I change it every 4-5 years , but do not drive too many miles (about 2,000 miles a years in both my cars)
Old Jan 4, 2013 | 08:47 AM
I change oil filter with every oil change,
That's awesome but he was asking about the fuel filer
Old Jan 4, 2013 | 10:23 AM
shurtual86's Avatar
Old Jan 4, 2013 | 10:27 AM
stupidgenius36's Avatar
Just Plain Rude!
I changed mine once around 50,000 miles which was at about 7 years old.
There was nothing wrong with it, but it was cheap. So i figured i might as well.
Old Jan 4, 2013 | 11:06 AM
SilverSkoundrel's Avatar
i got my 05 with 30k in 2010 & changed it @ 40k the same year. mine went from a weekend car to a DD
Old Jan 5, 2013 | 05:25 AM
pilatti1's Avatar
My '07 has 87k and I have changed it 1 time at about 40k so it is time again
Old Jan 5, 2013 | 06:11 PM
Cavero's Avatar
Ford's recommended interval is every 30k miles. They're cheap and easy enough to change that I don't see any reason to leave them in any longer than that
Old Jan 6, 2013 | 08:04 AM
I didn't know that Cavero. I did change mine around 40k and I'm darn close to 66k right now. I will do it soon
Old Jan 6, 2013 | 09:52 AM
DPHC13's Avatar
Changed mine at 80K and all kinds of crap fell out of it. They are super cheap and really easy to do so pick one up and do it today.
Old Jan 6, 2013 | 01:30 PM
Cavero's Avatar
It's right in the service schedule they put in the same pouch as your owner's manual. You've got till your next oil change, sounds like
Old Jan 7, 2013 | 01:50 PM
Katfish's Avatar
Anyone have a link to a How To for this?
Thx
Old Jan 7, 2013 | 03:21 PM
Just Plain Rude!
Thx
See if you can PM Tbone. He changed mine. I know it's not hard. It's just tucked up under the driver's side, near the door.
Old Jan 7, 2013 | 03:50 PM
Cavero's Avatar
If search doesn't do it for you, it's in the factory service manual
Old Feb 4, 2013 | 09:18 PM
mrkabc's Avatar
Gahhhhhh... I have 114,000 miles on my original fuel filter...
Old Feb 5, 2013 | 10:20 AM
MCK3125's Avatar
I've had mine done at the factory recommendedand one or two more times at the request of the tuners as I was having issues.So, with the mileage/age of my car it works out to changing it once every 9kmiles over 7 years. The filters are cheap and the job is easy.
Below are the instructions that Ifound on the Internet.
******Use at your own risk.*******
  1. With the vehicle in NEUTRAL, position it on a hoist. (I was able to do this with the car on the ground. It’s tight but doable.)
  2. Release the fuel system pressure.
  3. Disconnect the battery ground cable.
  4. Remove the 2 fuel bundle shield retaining bolts.
    • To install, tighten to 7 Nm (62 lb-in).
  5. Remove the 2 fuel bundle shield retaining nuts.
  6. Remove the fuel bundle shield pin-type retainer and position the fuel bundle shield aside.
  7. Disconnect the fuel tube quick connect couplings from both sides of the fuel filter.
  8. Release the fuel filter bracket mounting bolt
    • To install, tighten to 5 Nm (44 lb-in).
  9. Remove the fuel filter from the fuel filter bracket.
  10. To install, reverse the removal procedure.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
MustangConvert11
Sep 30, 2015 08:01 PM
southern stang
Sep 26, 2015 04:19 PM
