Fog Light Issues
Old Sep 15, 2005 | 10:19 PM
Realdeal's Avatar
Has anyone else noticed a bluish white haze on thier fog light reflectors. Took mine out today to tried and clean it but thier sealed. It seems to be worse at the top above the bulb obviously caused by heat. I removed the bulb and tried a few different things to wipe it off. One thing I do know is not to spray any type of cleaner inside the housing because the reflector is not metal its just cheap plastic with a reflective paint (price point) some of mine came off to reveal the black plastic beneath it. Im looking for some type of aftermarket housing to replace them with, any suggestions?
Old Sep 18, 2005 | 03:15 AM
WERKED 66's Avatar
go back to the dealer show him what happened..he should replace it...
Old Dec 17, 2005 | 11:35 AM
Galaxie's Avatar
I Have Admin Envy
Kevin,
Can you tell us if Ford has updated the part number on the GT foglamp assembly? It seems that a few members have noticed that the reflectors seem to be oxidized or worn out. The same goes for the headlight assembly
Thanks in advance
Old Dec 18, 2005 | 09:31 AM
05stangkc's Avatar
No, Ford Has Not Updated the Headlights to my Knowledge. Ford will monitor Warranty Replacements and Ck for Frequency of Repairs. If enough Repairs are Logged a TSB May be Issued. In the Meantime Take it to your Dealer and Voice your Concerns.
Old Dec 18, 2005 | 09:58 AM
05stangkc's Avatar
http://forums.bradbarnett.net/index....opic=22896&hl=
If you Have a Concern Here is The Process to Follow!
kc
Old Dec 20, 2005 | 06:17 PM
alankljuc's Avatar
YES! MINE HAS DONE THE SAME THING AND I HAVE ONLY 4,500 MILES. THE INSIDE OF THE FOG LIGHTS ARE FOGGING AND HOPEFULLY, MY DEALER WILL REPLACE THEM IN THE SPRING WHEN I GET IT OUT OF WINTER STORAGE. BY THE WAY: IF YOU EVER GET "OUTSIDE" FOGGING OR HAZE ON ANY PLASTIC LENSES, USE McGUIRES P L A S T I C X CLEANER FOR PLASTIC LENSES - IT IS FANTASTIC!!!
Old Dec 20, 2005 | 07:36 PM
94tbird's Avatar
same problem here
Old Dec 21, 2005 | 05:04 PM
jim's06's Avatar
Ditto same problem, 1 month old, but I do use my fog's every day.
Old Dec 22, 2005 | 08:35 AM
adrenalin's Avatar
Had the same problem but the dealer replaced the fogs.
Old Dec 22, 2005 | 11:47 AM
Fastrack's Avatar
What warranty would this fall under? 1 year ?
If the 1 year hopefully i don't have this issue as my car will only have 1 month warranty left after storage!
Old Dec 22, 2005 | 05:23 PM
adrenalin's Avatar
according to my dealer it falls under the 3 year/60,000km warranty
JT_Kwik
Nov 29, 2022 01:45 PM
seaclam
Sep 25, 2015 01:29 PM
DrisStang
Sep 14, 2015 06:20 PM
DEPUTY62
Sep 12, 2015 11:12 AM
14Glassback
Sep 11, 2015 04:50 PM
