First Dyno Run / Mustang Dynometer
Old May 26, 2005 | 07:55 AM
MaverickMLFD371's Avatar
Thumbs up
Went to a buddy of mine's shop that he just opened and the facility came with a Mustang Dynometer. Put it up and got 2 stock pulls, best pull was HP 245 with FT-LBS 254 @ 6000 RPM. Does that sound right??? I know you lose a percentage while your on the dyno, but I'm asking for those who went on a dynometer if they got roughly the same numbers. I don't have the sheet scanned cause Im at work, I'll scan the sheet later 2nite and post it...... any opinions?
Old May 26, 2005 | 08:05 AM
1999 Black 35th GT's Avatar
Sounds a little low to me. I would think it would be more of 265-270 hp and 270-275 trq. Hmmm, don't know for sure though.
Old May 26, 2005 | 09:14 AM
wild stray's Avatar
Numbers would be low if it were a DynoJet, but prolly right on for a Mustang Dyno.
Paul
wow, all these views and one post? I guess I'll go under the assumption that the number is good, i dunno, I'm not dyno smart.....? Like I said, its my first time there.....
Old May 26, 2005 | 10:11 AM
wild stray's Avatar
Bryan (2005redgt) posted his first dyno run on Mustang Dyno at 255rwhp some time back. You might want to do a look-up on him as he had a web site devoted to his car. Should give you some good info also as to his subsequent mods and outcomes. Believe Bryan's car is an automatic.
Paul
Old May 26, 2005 | 10:12 AM
Stubbies's Avatar
The two different dynos you see used give different readings, like Wild Stray suggested. You also didn't mention manual or auto, that also changes loss through the drive train.
Old May 26, 2005 | 10:39 AM
mines a manual.....
Old May 26, 2005 | 03:45 PM
Greywolf's Avatar
Also the technique of the dyno operator effects it . And on Mustangs Dyno you have to enter a weight as the drum used electo magnetic resistance. Plus air temp humidity all effect the out come. Is your number adjust for atmosphere and altitude?
Old May 26, 2005 | 03:56 PM
mach1fever's Avatar
yuppers expect about a 11% difference in mustang vs dyno jet. Mine put down 282 rwh and 318 ft lbs on a mustang dyno
Old May 26, 2005 | 03:58 PM
2005RedGT's Avatar
Sounds right for a Mustang Dyno with a Manual Tranny with no Mods. However, the Torque looks a bit low. For a frame of reference: My auto was 232 rwhp on the Mustang Dyno stock.
-Bryan
Old May 26, 2005 | 04:06 PM
AFBLUE's Avatar
Dethroned Nascar Guru
Mustang dynameters do give lower #s than dynojet. My 96GT dynos 245rwhp on a mustang and 267rwhp on a dynojet (supercharger).
So you should expect about the same.
267rwhp is about average from what I've seen for 05 dynojet runs, so you are right in there.
Ecostang
Nov 3, 2022 08:50 PM
5.8KB
Sep 10, 2015 07:00 PM
Mackitude
Aug 13, 2015 01:05 PM
Jul 20, 2015 06:26 AM
Ecostang
Jul 11, 2015 09:06 AM
