Drained Tranny Fluid from pan, can I drive it 2 miles to shop?? Or have it towed?
Old Jun 8, 2008 | 12:07 AM
Mustang734's Avatar
Not quite sure why I allowed my son to try and change the oil in my stang, but I did. Instead of him draining the oil, he decides to drain the transmission fluid from the tranny pan. So my question is, do I need to have my car towed now to the shop?? Or can I drive it the 2 miles to there?
Old Jun 8, 2008 | 12:23 AM
Gearhead's Avatar
Absolutely do not drive the car. Both my Mustangs are manual transmissions which have fill plugs, but I understand that the automatics maybe don't have a fill plug? If they do, then just get make-up fluid and a pump and refill it yourself. If not, you may have to have it towed to a shop to get the fluid pumped-in from a cooling line or something like that. Any autobox users know further here?
Also, we learn from our errors. It is good that your son was trying.
Old Jun 8, 2008 | 06:07 AM
GrayPony's Avatar
Do not drive... tow there is no way to fill the trans without the special tool. (some have pulled the pan, filled it, then carefully put it back full before making the trip to the dealer) To me it would be easier just to have it towed to the dealer .
Old Jun 8, 2008 | 06:20 AM
topbliss's Avatar
you can fill the removed quarts thru the dipstick hole. DO NOT even start the car. The trans will be damaged.
Old Jun 8, 2008 | 06:51 AM
MustangGuy's Avatar
Would it have plunged Ford into insolvency to have added a normal dipstick to the automatic Trans?
Old Jun 8, 2008 | 07:48 AM
adrenalin's Avatar
As already stated, do not drive the car.
Closing thread since you already opened one for the exact same topic in another section..
http://forums.bradbarnett.net/showthread.php?t=469017
EaterofWorlds
Nov 23, 2015 08:51 PM
Fastryker
Aug 7, 2015 05:28 AM
southern stang
Jul 29, 2015 08:41 PM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
