dot 4 brake fluid instead of dot3
Old Jul 28, 2015 | 12:42 PM
southern stang's Avatar
Hi all, had my brake fluid drained and replaced by Ford Dealer. Noticed they refilled with dot 4 fluid instead of dot 3. The owners manual states only refill with dot 3. Did they make a major mistake or am I ok running with dot 4? My car is an 07gt. Thanks everyone
Old Jul 28, 2015 | 03:42 PM
Joeywhat's Avatar
Dot 4 had a higher boiling point. Otherwise it is 100% compatible.
Old Jul 29, 2015 | 08:41 PM
09-gt/cs's Avatar
Yeah sometimes part numbers get superseded. My ranger called for older mercon tranny fluid which is no longer produced and got upgraded at the last service. It should be fine but if your concerned usually google has a pretty good table that shows the new specs for fluids based on what they are currently using. Or the dealer can show you they keep that stuff logged in the computer.
boz
Oct 1, 2015 04:47 PM
Rando
Sep 30, 2015 12:28 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
