Cosmetic factory issue
So, I cleaned/waxed my car today for around 4 hours, and I noticed something sumdged on my back right side window. Not just a small smudge, but I very long one. I scrubbed and scrubbed from both sides of the window, inside and out. I used goo - gone, I tried everything. I finally came to the conclusion: Someone got their fingerprint on the inside of my glass. I do think it is double sided, I'm not completely sure. I wish my camera worked so I could get a picture of it.
Anyway, I called my dealer, and they said it would be covered in the cosmetic part of the warranty, so the window will be replaced in the spring when I drive it again.
Wow, springtime will mean lots of changes for my car ... stripes, new window, sequentials, and while they are working at the windows, I just might have them tinted.
I just think its kinda odd though to have that fingerprint in there...
Well, no, I probably will, its not just a fingerprint, rather, it seems whomever put in my window had grease or something on their gloves because its a smear of something, but I can see the fingerprints in there.
DJ07,
I had the same problem, on the same window. During the cleaning process, I realized that the window was not sealed properly and, at a certain angle and pressure, water could get into the car.
I had it replaced for the leak issue, the new one did not have a print on it.
Might as well get it perfect while someone else is footing the bill. Even if it wasn`t noticable with the tint, You would still know it is there. BTW, hope to see you out on the streets o C-Town. I`ll be the one in the silver GT w/ Titanium stripes.
Originally posted by workingOn3@December 19, 2004, 12:48 PM
DJ07,
DJ07,
Since then I have not had any leaks, so I will just sit back until I notice more streaks.
My front window has a section that looks like a piece of tape was on it. This appears only if the window is fogged up. I have tried removing it but no luck. The dealer will look at it this week. It is not a big deal, but this is the second windshield in the car since the first one was cracked during transportation.
Well, the Ford Job #1 sticker is on the other window...
also, my driver side door, when you open it, down by the rocker panel, it still has some plastic stuck to it and sticky stuff that wont come off it.
