Clutch help
Clutch help
Hey guys I was needing a lil help regarding my 07 gt I was driving down the road stopped @ a red light and went to put the clutch down and the clutch just dropped and had no tension i let off and went to push on it again and it still had no tension so I pulled over and a lil bit of smoke started to come out from under the hood. I think the clutch disc went out or the pressure plate went out. But not sure if someone would help me on this I would appreciate it. Thanks.
I had the slave cylinder go out on my 1990 T-Bird SC at 2am once. It had a separate fluid system from the brakes, but I still had to get towed home because the towing company would not bring me a bottle of brake fluid.
Well the dealer just called me to tell me that my car was done and that it was not the slave cylinder. The problem was the line coming off the slave cylinder had a crack in it.
When I took my car to a dealer to have the FRPP SS clutch line installed , it cost quite a bit more than I was expecting. The fitting is on the top of the trans and they said they had to drop the engine and trans to get to it , so it was several hours labor ...
Sep 23, 2015 03:21 PM
JonathonK
Sep 19, 2015 03:19 AM
