Changing clutch fluid
It has been 5 years now sice I bought my car new. I figured it was time to do a complete R&R of the brake/clutch fluid and the coolant. My question is how do you get old the fluid out of the clutch line and slave cyl? It is the craziest design I have ever seen. On th 05 it actually has a bleeder but is pretty much inaccessible with the tranny in the car.![Banghead](https://themustangsource.com/forums/images/smilies/banghead.gif)
Any help is appreciated...
Thanks, Dave
Thanks, Dave
Thanks, Dave
Thanks, Dave
That system must be nothing like the new mustangs clutch hydraulic system. I think you are missing my point completely, do you understand what my question is? Take a look under the hood of your car, getting the fluid out of the reservoir is not the problem here. Just bleeding the brakes will purge all the fluid from the reservoir...but what about the fluid in the line leading down to the slave and the fluid in the slave itself??? How do you remove and replace this fluid without removing the tranny to gain access to the slave cylinder?
Thanks, but i have these instructions. This is how to bleed AIR ONLY out of the clutch slave cyl, that is not my question, I want to get rid of the old fluid. This proceedure is real good when you are replacing the slave cylinder or replacing a clutch to bleed the air off after replacing with the new fluid
I am unable to flush my brake line because the bleed screw is frozen just like you say you cannot flush your line completely.
But the fluid mixes everytime you use the pedal. So, like I have to do with my F150 frozen bleed screw, I suck out and replace fluid in the reservoir. (Do not suck out 100% until res is completely empty because you do not want to expose any air to the line. As I said, you could do this a couple of times if you are overly concerned about getting as much new fluid in as you can.)
While it would be better to be able to flush properly, I have been doing this successfully for well over 100k miles (my F150 has 250k).
Just an idea for another solution for you.
Yes I think I understand though I haven't crawled under your car.
In your info it says you have a 2008 Bullit. I said to look under the hood of your car since it would be the same as mine. I really dont think the clutch fluid gets all mixed up with new fluid every time you use the clutch. I am sure the fluid in the reservoir just keeps air from getting into the line itself. thanks for the help but I don't care for this solution at all.
I can only tell you what has worked for 100k in a Ford product. And yes it mixes, I've seen it.
You're a heli mechanic, figure it out.
DerekShiekhi
9/30/15 06:59 AM
